What size tire would you go with for 19/9.5 rims?
Old Feb 25, 2007 | 08:01 AM
TheSurgeon's Avatar
TheSurgeon
Default What size tire would you go with for 19/9.5 rims?
I have a set of Axis Hiro in staggered configuration: 19x9.5 front and 19x10.5 rear. The front tires are pretty worn due to a camber problem that wasn't detected early enough.
I need to replace the front tires. I currently have 245/35/19 Toyo T1S. I always feel that the sidewalls can come out a bit more, so that the edge of the rims will not stick out.
I'm planning on going with 255/35/19 this time around. What do you guys think. Has any of you done 255 for the front? How would going wide for the front tires affect the handling? Thanks.
Old Feb 25, 2007 | 08:31 AM
If you go from a 245mm to a 255mm front tire, the increase in width is only 4 percent. I doubt that you will notice any difference.
Old Feb 25, 2007 | 10:40 AM
DavesZ#3's Avatar
DavesZ#3
I've got 255 up front and 285 on the rear. No problems with handling or traction at all.
Old Feb 25, 2007 | 11:11 AM
RamSiNx7's Avatar
RamSiNx7
yeah 255 front and 285 rear X35 would be best for more acurate reading on speedo....
Old Feb 25, 2007 | 03:46 PM
DavesZ#3's Avatar
DavesZ#3
... as well as keeping VDC happy
Old Feb 25, 2007 | 03:59 PM
Mike Wazowski's Avatar
Mike Wazowski
great sizes
Old Feb 26, 2007 | 10:32 AM
TheSurgeon's Avatar
TheSurgeon
Thanks, guys, for the input. 255 it is. I'm getting a pair of Toyo T1R 255/35/19 install this weekend. Hopefully they will last longer than the ones before them.
Old Feb 26, 2007 | 12:38 PM
Mazinger Z's Avatar
Mazinger Z
I have 255/35/19's up front on my 19x9.5 le's. No issues whatsoever.
Old Feb 27, 2007 | 01:51 AM
Chad68's Avatar
Chad68
You have 245's on 9.5" rims up front? Man that has got to be streched, like crazy. I have Hiro's and have 8.5" up front with 245/35 and even those are stretched a tiny tiny bit compaired to the flushness of the 275's on the 9.5's on the rear.
With your set up I would run 265 and 295's.
Old Feb 27, 2007 | 07:27 AM
ekim81's Avatar
ekim81
i think most people do 255 on the front... you can stick with the 245 if you want that stretched look.
Old Feb 27, 2007 | 09:22 PM
JETPILOT's Avatar
JETPILOT
275 30's up front on a 9" wheel, and 295/30 on a 10" wheel for the rear. Those are the appropriate width tires per manufacturer for those rim widths.
Check my cardomain for some pics. They fit perfectly.
JET
Old Feb 27, 2007 | 09:38 PM
redlude97's Avatar
redlude97
JET
great sizes if you track regularly or have the power to need those sizes, otherwise, IMO they are going to be to heavy feeling for a relatively stock daily driver with minimal mods
Old Feb 27, 2007 | 09:43 PM
Z-INCOGNITO's Avatar
Z-INCOGNITO
JET
same here... conti sportcontact2
ablaine
Nov 29, 2016 10:13 AM
