245/35ZR/19 and 275/35/19 - Have a flat
Old Feb 27, 2007 | 03:50 PM
HitLines's Avatar
HitLines
Unhappy 245/35ZR/19 and 275/35/19 - Have a flat
(dust from the shop)
Just received the bad news that my rear Azenis ST115 275/30ZR/19 has a leak near the sidewall. It looses about 15psi every day and cannot be repaired. I have only had the car a limited time but knew the back tires would need to be replaced soon. First time with an aspect ratio tires thus the help I seek.
On the car now:
Front: Azenis ST115 245/35ZR-19
Back: Azenis ST115 275/30ZR-19
The previous owner said he might have altered the ratio so I should fix that when I got new tires. This is what I am considering unless my mind is completely off which it could be since I was saving for a popcharger.
Nitto NT NeoGen ZR — 275/35ZR-19
Treadwear: 280
Traction: A
Temperature: A
Speed Rating: ZR
$212
Nankang NS-2 275/35ZR19
Summer only
Speed Rating: Y
$128 +shipping
Of course I want to get away with only 2 tires and not have to replace the fronts yet. Hopefully I can hold off on getting winter tires on the original 17s. Also it would be nice to get the TPS into these 19s if possible. The shop said it was not but I have read on this board that you can.
P.S. Also has hotchkis front and rear sways.
Old Feb 27, 2007 | 05:12 PM
Nihilation's Avatar
Nihilation
275/35/19 would be the correct rear tire size. I'm not sure what you're asking really. It's best to run the same model tires all around if you can. As I've said in other threads, the only thing connecting you to the road are the tires so don't be cheap when it comes to replacing them.
Old Feb 27, 2007 | 05:15 PM
Nihilation's Avatar
Nihilation
I posted in another thread about this as well but the Falken FK452's are pretty good and edgeracing.com has them for $280ea for the 275/35/19's and $170 for 245/35/19's. The T1-R's are $197 for the fronts and $218 for the rears...
Depravity
Oct 1, 2015 04:49 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
roadmax
Sep 12, 2015 05:55 PM
