Need Help with Tire choice
Old Mar 18, 2007 | 03:36 PM
Sunset350ZR's Avatar
Sunset350ZR
Question Need Help with Tire choice
First yes I have searched and because question has multiple levels to it, I need some help.
I am getting some Ruff 278 18/9.5/+20 rims rear and 18/8.5/+20. I am now looking for tires. I was thinking that 275/40/18 rear and 245/40/18 should work without rubbing.
Issues I am trying to avoid
a. Speedometer reading off.
b. TCS being affected
c. rubbing
a. What does the speed sensor read. I am ignorant of this. If it reads wheel speed, which wheel as I would like to be as close as possible.
b. Don't think this will be a problem as I am below the 3% threshold every writes about.
c. Don't think this should be a problem ither as I have seen a lot more aggressive setups that owners say don't rub. My car is not lowered either but do plan to do so before summer '08.
Any ideas or advice I would appreciate greatly and if I have missed something in the search that will answer my questions point me in the direction please, but I would like some persoonal thoughts on those that have experience with this.
TIA
Old Mar 18, 2007 | 04:30 PM
A tire calculator is your friend. Match the OEM tire height, and the speedometer will be fine.
TCS is less susceptible to problems the VDC, still, I recommend that the rear tires be 10mm taller than the front.
Old Mar 18, 2007 | 06:23 PM
Sunset350ZR
I did the tire calculators already how I got the tire specs I have there. Why does rear need to be 10 mm taller?
Old Mar 20, 2007 | 08:19 AM
Sunset350ZR
bump
Old Mar 20, 2007 | 09:05 AM
TCS can cope with just about every tire set-up. Here the rear tires are 24 mm taller than the front. I see no problem.
ablaine
Nov 29, 2016 10:13 AM
kyin
Oct 15, 2015 05:54 AM
