which spacers with 19" rims and nitto tires
hi i just placed an order for some 19"x8.5 and 19"x9.5 rims with an offset of 35 f/r, and some nitto 555 245/35/19 front and 275/35/19 rear. i was wondering what would be the best spacers for this combination. i was thinking of some 10mm spacers for the front and either 10 or 15mm spacers in the rear. how would that look? and would it fit without rubbing. thanks
(i want the rim and tires to be as flush with the fender as possible.) thanks
I'm running 19x8.5 in the front and 19.10.5 with the same tire sizes you have and I do not rub and I'm dropped on Hotchkis springs with +22 offset in the front and rear so you can use that as a gauge if you would like.
you can use this to guage what size spacer you would need. im thinking you could go with at least a 20 mm spacer without rolling your fenders...bigger spacer if you want to roll them
http://1010tires.com/WheelOffsetCalculator.asp
was the the most agressive offset you could have ordered?
thanks for the link.
35 was the most aggressive offset that was available in that specific rim.
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
