hubrings?
Old Apr 11, 2003 | 09:54 PM
biscotti's Avatar
biscotti
Smile hubrings?
For those members who have aftermarket wheels, did you need to use hubrings? Thanks in advance for any replies.
Old Apr 12, 2003 | 08:40 AM
TXSTYLE's Avatar
TXSTYLE
Default Re: hubrings?
I sure did! And MOST aftermarket wheels require the same. Since they were not manufactured specifically for 1 application.
Old Apr 12, 2003 | 08:41 AM
john350Z's Avatar
john350Z
the te-37s came with hub centering rings for the z
Old Apr 12, 2003 | 08:45 AM
TXSTYLE's Avatar
TXSTYLE
So did my Anterea's, MODA's, Fondmetals, Enkei's, and every other AM wheel I bought. They are suppossed to, but you can always get em' from a reputable tire shop.
Old Apr 12, 2003 | 05:52 PM
biscotti's Avatar
biscotti
Thanks for all the replies guys. I love this forum.
Old Apr 13, 2003 | 06:56 AM
2003z's Avatar
2003z
iforged didn't come with them, enkei rpm2s didnt come with them, enkei rpo2js came with them.
Old May 6, 2004 | 02:47 PM
pixelninja's Avatar
pixelninja
yeah, my Volk CE28N's came with the plastic ones, I decided to go with metal ones instead. I've got a few extra sets if anyone here needs them for their Volks or other wheels with a 73mm bore.
Old May 6, 2004 | 09:54 PM
Jsn350Z's Avatar
Jsn350Z
What could happen if you do NOT use them?
Old May 7, 2004 | 08:55 PM
pixelninja's Avatar
pixelninja
It's possible that you could develop a vibration, and add extra stress to the studs/lug nuts.
The wheel is designed to "sit" vehicle's hub, while the lug nuts hold it in place. If the vehicles hub doesn't mate with the wheel, then your lug nuts/studs are basically left to do the job of both.
Old May 8, 2004 | 11:04 AM
fresno350's Avatar
fresno350
i got the plastic ones from axis. they said they just make sure your wheel is centered when it goes on.
Old May 9, 2004 | 12:32 AM
D'oh's Avatar
D'oh
Most good tire places will give you a set of plastic ones for free when you get your wheels. If they forget, you can just stop by and ask nicely. When I got my race wheels from America's Tire, they forgot the hub rings. I used a lugcentric mounting arrangement (where the lugs hold the wheel centered) and it worked fine, but was a royal pain to change wheels before and after races (because you have to support the wheel as you tighten the lug nuts so that everyting is centerd nicely and so you don't scratch the rim holes with your socket). I went back to America's Tire and they orderd the lug rings and I just picked them up when they arrived. No cost to me.
-D'oh!
Old May 10, 2004 | 04:19 PM
Strife350z's Avatar
Strife350z
anyone know what inner bore diameter I need when asking for hub rings? is it 66.1?
Old May 11, 2004 | 06:49 AM
D_Nyholm's Avatar
D_Nyholm
I was looking at getting some mustang wheels to use on my car for drag racing, but I have no idea what size their hub is or what size our hub is. Does anyone know either one???
Tirerack wouldn't help me. I wonder if discounttiredirect would?
Old May 11, 2004 | 09:26 AM
havabooz's Avatar
havabooz
strife...inner bore (meaning nissans hub size) is 66.06mm
Old May 11, 2004 | 09:19 PM
Strife350z's Avatar
Strife350z
great, thanks havabooz!
Old May 12, 2004 | 05:19 AM
havabooz's Avatar
havabooz
np....make sure you get the plastic or composite ones..cause i heard that metal ones will have some kinda reaction with the metal on the wheel....got mine from prestigewheel.com
Z1 Performance
Mar 5, 2012 05:03 AM
Z1 Performance
May 2, 2011 10:20 AM
Z1 Performance
Apr 5, 2011 12:30 PM
