Wheel/Spring Help
Old Apr 3, 2007 | 10:19 AM
Tomci08's Avatar
Tomci08
Default Wheel/Spring Help
Ok guys i have searched the site and can't get a good answer on this. I have a 06 Z with the 19 inch nismo wheels on it and not just purchased the tokico d-spec struts with eibach pro-kit springs. I want to put everything on but am worried if i need to roll my rear fenders or not? Does anyone have this set up on their cars or do you know if i will have to roll the fenders or not? i am running a 19x9.5 rear wheel with a 275/35 tire. Any help is much appreciated. Thanks
Tom
Old Apr 3, 2007 | 03:11 PM
1nate7's Avatar
1nate7
If you have the typical conservative Nismo offsets then there will be no issues, should be plenty of room.
Old Apr 3, 2007 | 03:24 PM
plumpzz's Avatar
plumpzz
^+1. I have 18 X 10 +18 offset w/ a 275/40 tire. I required rolling. That setup drops the same as my setup.
Old Apr 3, 2007 | 04:33 PM
Tomci08's Avatar
Tomci08
They are the typicla 19 inch Nismo's with the +25 offset i believe? So it looks like from my above reply's that i am good to go with no rolling required?
Tom
