Whats The Best Rim Size?
Old Apr 17, 2007 | 02:54 AM
THE BARRON's Avatar
THE BARRON
Default Whats The Best Rim Size?
im going to be buying some rims pretty soon. im thinking of the piaa supermesh 2 but any way im not sure what size i should get. i want to go with either a 18" or 19" whats the pro's and cons of both setups? i want the car to mostly look good but i do plan on takeing it to the track for track days once in a while. i dont really plan on drag racing. so i guess what im getting at is what size is better for the road track? and whats better for the street?
thanks
Old Apr 17, 2007 | 05:34 AM
For performance go forged 17-inch wheels
For bling go cast 20- inch wheels.
Anything between is a compromise.
Old Apr 17, 2007 | 06:27 AM
SB04's Avatar
SB04
get what you are happy with for looks and price...tires for 19's and 20's are considerably more $$ than 18's
Old Apr 17, 2007 | 06:32 AM
AbsolutSpeedZ's Avatar
AbsolutSpeedZ
I personally like the look of 19's a lot better, as a rule of thumb, and I'm sure some people would agree with me, but when getting aftermarket wheels, I usually go up an inch over my stock wheels. Since I had 18's as stock, I went with 19's. SB04 is right, tires from 18 to 19 do have a good jump in price. As far as width, some guys do 8.5 front, 9.5 rear, which is a full inch wider in the rear. I did a 9.5 front and 10.5 rear, low offset, which gives you a wider wheel and a more bad *** look.
Old Apr 17, 2007 | 06:53 AM
Ziggyrama's Avatar
Ziggyrama
I think anything over 18" is going to seriously compromise the perfromance, both in power and braking. Even forged 19s will have significant weight to them. Add the tire that is further away from the center of rotation and you have significantly larger inertia in that wheel.
I think 18s offer best look/performance compromise but then I am more of a more go/less show type of guy
Old Apr 17, 2007 | 06:58 AM
scotts300's Avatar
scotts300
Very well summarzied. A few additions:
track: 17" forged - agreed. Plus cheaper tires.
Bling: 19-20", expensive tires. The higher the quality the wheel (fabrication technique) the higher the cost.
Best might be to go in the middle at an 18", although I'd never track my street wheels and tires. Use your stock set for track until you have enough coin for a better track-only set-up.
Old Apr 17, 2007 | 06:59 AM
push's Avatar
push
22"
Old Apr 17, 2007 | 08:09 AM
Korki Buchek's Avatar
Korki Buchek
I thought we figured out that there wasn't much difference in performance between 18-20 if you're using it for (even pretty hard driving) street applications?
Old Apr 17, 2007 | 08:11 AM
djnc's Avatar
djnc
i ran a statistical regression and suprisingly enough, 25.63" diameter wheels would be the optimal size...so get 26's
Old Apr 17, 2007 | 08:14 AM
Question
What tires do you recommend using the regression thing?
Old Apr 17, 2007 | 08:16 AM
djnc's Avatar
djnc
What tires to you recommend using the regression thing?
well, the system says to go with 25.63 x 13 wheels with 215/40/25.63 with a -50 offset...computers like ghetto VIP whips, son
Old Apr 17, 2007 | 08:19 AM
Ziggyrama's Avatar
Ziggyrama
How did you guys figure that out? I hope it wasn't the good ole but dyno
Any weight you can shave off the corners will help. Generally, 18s will be lighter than 20s, by at least a couple pounds. I'd say that is noticable when you drive the car. I know I notice. The overall weight is one thing. Changing aspect ratios changes weight distribution oof the wheel and tends to push more weight towards the other edge of the wheel diameter. That will compound the effect and make you even slower.
Old Apr 17, 2007 | 08:22 AM
widebody350's Avatar
widebody350
19s for me.
Old Apr 17, 2007 | 04:06 PM
Fooshe's Avatar
Fooshe
The man knows what he talks about. Remember that the width is just as important...Don't go too wide. 9.5 is the max is the max you want to go.
My track wheels are 9.5 fronts (275/35/18's) and 10.5 rears (295/35/18's). While I stick VERY well, my stocks just spin up faster.
Rolling resistance is a powerful thing.
Old Apr 17, 2007 | 04:09 PM
drooke's Avatar
drooke
12 inch
Old Apr 18, 2007 | 06:59 PM
TimeAttkZ's Avatar
TimeAttkZ
We all know 17's would be ideal for performance .. but lets face it .. they look like $hit In my opinion ... 18's are best for performance while maintaining a stylish look. 18's give you great tire choices as well. 19's your compromising a little performance but go with some high quality light weight wheel and your not that bad. They look visually the best at 19's I think. 20" is just stoopid and out of the question. Buy a Chrysler 300c on dubs if thats your interest.
For width .. I think 9.5 front 10.5 rear is perfect for running a nice size tire for traction while not being overkill. Looks nice and aggressive. Anything under a 9.5 is no bueno... again for anyone who disagrees ... these are not facts, its my educated opinion.
Thats why my set-up is Volk Time Attacks 19x9.5 +22 front 19x10.5 +22 rear. I'll be throwing on my spacers in the rear too shortly after I get my coilovers on.
Old Apr 19, 2007 | 12:37 AM
Korki Buchek
Old-school gold BBS 14's.
sales@czp
Sep 23, 2019 03:30 PM
ablaine
Nov 29, 2016 10:13 AM
