offset for volk 19x9.5f and 19x10.5r
Yeah...if you have the SF Winnings...then your offset might be alittle bit higher...
The +17/+18 offset is only for the VOLK GTS wheels
I think that the SF Winnings would be alittle bit higher...in the 20's???
Performance Nissan
Performance Nissan
TE37/CE28 - +22F/+22R (Mild) +12F/+12R (Aggressive)
GTS - +17/+18 (Aggressive)
SF Challenge - +28F/+23R (Mild) +15F/+11R (Aggressive) +11F/+11R (Super Aggressive)
SF Winning - +19F/+17 (Aggressive)
GTF - +17F/+15R (Aggressive)
GTM - +23F/+21R (Conservative/Mild)
Keep in mind that aggressive fitment may require fender rolling, camber adjustments, narrower tires, and no use of a BBK.
About the BBK clearance, does that apply to all of the wheels or just some? Some wheels may retain the same curve and spoke design that allow you to clear the BBK regardless of offsets?
