Can I use my stock rubber with these wheels?
Old Apr 29, 2007 | 04:11 PM
d!abolic's Avatar
d!abolic
Default Can I use my stock rubber with these wheels?
Rota PF45 18x9.5
Old Apr 29, 2007 | 04:37 PM
plumpzz's Avatar
plumpzz
You should be fine. It'll be stretched a bit. Not much though.
Old May 1, 2007 | 03:18 PM
d!abolic's Avatar
d!abolic
Thanks. Can anyone confirm?
Old May 3, 2007 | 07:04 AM
d!abolic's Avatar
d!abolic
Originally Posted by d!abolic
Can anyone confirm?
Old May 3, 2007 | 07:38 AM
Mikesamillion's Avatar
Mikesamillion
im looking at these wheels too. where you buying from? pm me if you want
Old May 3, 2007 | 08:17 AM
HondaKiller's Avatar
HondaKiller
245 will stretch but a 235 will run a little short on my opinion. Were the 18's 245-255?
Old May 3, 2007 | 08:52 AM
dan avoN7's Avatar
dan avoN7
You can run stock rubber on them but they will be stretched a little. fine for daily driving but if you plan to really push the car hard in turns then I would look at wider tires to suit the wheel.
Subydude.com is the place to go for these wheels.
Old May 5, 2007 | 07:45 AM
d!abolic's Avatar
d!abolic
I'll check.
Old May 5, 2007 | 07:46 AM
d!abolic's Avatar
d!abolic
What'll happen if I really push it with stretched rubber?
Old May 5, 2007 | 08:01 AM
Korki Buchek's Avatar
Korki Buchek
Old May 5, 2007 | 10:38 AM
JDMFairladyZ33's Avatar
JDMFairladyZ33
You guys are all wrong. Each tire and wheel has their own min/max application threshhold. If you have the factory 245/45/18s RE040s, the min/max wheel width required is 7.0-9.0". It's not 9.5". Even though some people stretch their tires on larger wheels, it's considered an unsafe application because your tire's bead is not properly set and the sidewalls will not have the proper support. For 9.5 you need at least a 265 for good fitment. Consult the tire's application chart on the web if you doubt what I am saying.
350Z_Al
Oct 29, 2020 07:44 PM
ablaine
Nov 29, 2016 10:13 AM
Depravity
Oct 1, 2015 04:49 PM
