Help me plz...car is not going straight!!!
Old May 3, 2007 | 12:37 PM
flynbrin's Avatar
flynbrin
Question Help me plz...car is not going straight!!!
hey guys,
i just got an alignment done to my car
but my car is still pulling right
in order to drive straight, i have to turn my steering wheel slightly to the right
do i need to have something else done in order for my car to go straight?
thanks
Old May 3, 2007 | 12:38 PM
Tubbs's Avatar
Tubbs
Yes, go back to the alignment shop that fucked up.
Old May 3, 2007 | 12:39 PM
JDMFairladyZ33's Avatar
JDMFairladyZ33
If the alignment is straight and it still pulls have them adjust the steering wheel. If that doesn't help then you might have radial pull coming from the tires.
Edit: No Joke..if you are fat have them do the alignment with you in the car. It makes a difference.
Old May 3, 2007 | 12:46 PM
Eazzy's Avatar
Eazzy
That was cruel to say in front of Tubbs. But true, and in fact gas tank should be at a good level
If your car pulls, they fukced up on the alignment or you have a belt separated tire. Have your tires balanced first at a quality place. Then if that chcks out take it back to the aligner and tell them if they cant do it right you want your money back and take it to a place that knows what they are doing
Old May 3, 2007 | 12:51 PM
Eazzy's Avatar
Eazzy
BTW--Steering wheel is apples and oranges---If it is aligned properly it could be at 2 oclock and the car will drive sraight with your hands off it. A cocked steering wheel is an inconvience and sloppy details on the part of the aligner but is a separate entity
Old May 3, 2007 | 12:54 PM
JDMFairladyZ33
LOL I was really serious about the fat comment. I've seen alignments "gone wrong" several times even though the tech swears everything was in spec. Turns out the owner of the car was fat and he was throwing everything out of wack. As for the tires, it may not be a separated belt. If he did have a separated belt that would be very easy to spot on the balancer. This is what he should do:
1) Make sure the alignment is good
2) Check the tires for separated belts or uneven wear. If you have bad alignment wear from your old tires then the pattern is already set. You might need a new set of front to correct the problem.
3) If both of the above checks out then you might have what they called radial pull from an out of round tire. Have the tire techs do an 180 on the front tires and rebalance them. If that does work then have them swap the tires in the front. If the problem goes away or the car starts pulling the other way then you will know for sure it's the tires.
Old May 3, 2007 | 12:58 PM
I1DER's Avatar
I1DER
If it is pulling right, then it may be the gf in the passenger seat. Boat bumpers hanging out on the starboard side could cause it too.
Old May 3, 2007 | 12:59 PM
Tubbs's Avatar
Tubbs
Do you have an address my lawyer can contact you at? I figure 65 mill will cover my distress at your comment.
Old May 3, 2007 | 01:20 PM
flynbrin's Avatar
flynbrin
hahaha
thanks for the fast replies guys
i gotta go back and see whats up
thanks alot
Old May 3, 2007 | 01:28 PM
chriskabobbers's Avatar
chriskabobbers
the shop didn't do a correct job. your warranty will make them fix it
Old May 3, 2007 | 01:50 PM
ke0ki2k's Avatar
ke0ki2k
rotate tires
Old May 3, 2007 | 02:13 PM
Does the vehicle pull to one side? Alignment should take care of the problem.
Is the steering wheel of center?
Disconnect the linkage.
Center the steering wheel.
Put the linkage back together.
Old Jun 11, 2007 | 08:24 AM
MJM Z's Avatar
MJM Z
Is this something I can do myself with minimal skill and tools? Mine came from the factory with the steering wheel slightly off center. (Alignment is good, just minor inconvenience/looks issue)
Old Jun 11, 2007 | 08:25 AM
Ghost 350z's Avatar
Ghost 350z
Old Jun 11, 2007 | 09:11 AM
Eazzy's Avatar
Eazzy
It took some time but my attorneys say that I must have left my computer unintended and an unauthorized person tryed to frame me.
Yes..... Thats it ....a scoundrel... a hooligan
Old Jun 11, 2007 | 09:13 AM
Eazzy's Avatar
Eazzy
They insinuated it may have been a Canadian terrorist
Old Jun 11, 2007 | 09:20 AM
AroundMyHorn's Avatar
AroundMyHorn
did you hit something?
I went an got an alignment done and it pulled even worse than before!!! So now there telling me need a new compression rod (wtf is that?). I had them order the part and once they get it in Im going to tell them to put my car on the lift so i can see said damaged part.
Depravity
Oct 1, 2015 04:49 PM
