2007 enthusiast TPMS
Old Jun 8, 2007 | 05:00 PM
350Zimo's Avatar
350Zimo
Default 2007 enthusiast TPMS
does the 07 have a TPMS , i cant see it on my dashboard nor can i see it on my digital monitor in the middle on the dash , does the enth. have it ?
Old Jun 8, 2007 | 05:08 PM
ZCARBANDIT's Avatar
ZCARBANDIT
it should have one. i believe they all are starting to use it. if your valve stems are metal and not rubber u have it.
Old Jun 8, 2007 | 05:14 PM
ZCARBANDIT's Avatar
ZCARBANDIT
here you go for reference materials.
http://www.nissanusa.com/z/specifications-coupe.html
Old Jun 8, 2007 | 05:24 PM
DavesZ#3's Avatar
DavesZ#3
Yes, you have the TPMS, but for some idiotic reason, Nissan dropped the display of the actual pressures. All you will get is the warning if the pressure drops too low.
IOW, your pressures are being monitored but not by you.
Old Jun 8, 2007 | 10:09 PM
350Zimo's Avatar
350Zimo
Default Tmps
Yes my valve stems are metal , and i tore my tire two days ago (really bad on a road metal plate you know they put allover the road when there is a construction) so it did not DETECT any low tire presure or things such as TPMS light or i dont know, i will ask the dealer tomorrow. or at least i didnt notice any litghts to have been set off (on the dash) ?????
Old Jun 8, 2007 | 10:11 PM
350Zimo's Avatar
350Zimo
Smile
Yeah you are right the TPMS comes as a standard option of safety on the Z , so i gues when you tear a tire it won't tell ya that you are running on a rim only
_bit
Oct 2, 2015 07:49 AM
Alexreyes
Sep 30, 2015 11:30 PM
