8.5 F 9.5 R
Old May 3, 2003 | 09:12 AM
350zroadster's Avatar
350zroadster
Default 8.5 F 9.5 R
Have question for you people with different size front and rear tires, how would you rotate the tires to even out tread wear? Also what if the tires were directional?
Thanks
Old May 3, 2003 | 09:18 AM
mcclaskz's Avatar
mcclaskz
To my knowledge all 350z both with stock and aftermarket wheels have different size tires front to back. To answer, you do not rotate them. If you are driving the car like you should, you replace them every 15k or less. This is part of owning a sports car.
Old May 3, 2003 | 10:12 AM
Spoe's Avatar
Spoe
You can do a side to side swap at most, depending on your tires.
The stock tires a directional, so rotating side to side involves removing the tires from the rims and remounting. If you have nondirectional tires it's simple. If you have directional, asymmetric tires you can't do anything.
bcoffee20
Nov 19, 2015 06:39 PM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
