19 x 9 F & R
Old May 4, 2003 | 12:29 PM
350zroadster's Avatar
350zroadster
Default 19 x 9 F & R
What is too thick or too big of tires/wheels? are 19 X 9 front and rear too wide? Would it make turning more difficult? Thanks
Old May 4, 2003 | 12:33 PM
Stone Z's Avatar
Stone Z
Question Re: 19 x 9 F & R
19x9 is definitely a good size for the rear. 19x9 might be right at the limit for the front, but I think you'll be ok. You could run 245/35 & 275/35 without a problem. What are the offsets of the wheels?
Old May 4, 2003 | 04:36 PM
joeshow750's Avatar
joeshow750
I have heard people here say that the steering is a bit heavier with the wider tires up front, but nothing that they were concerned about. Most people do use a staggered setup though, even though using equal width tires may help with the understeer.
Old May 4, 2003 | 04:49 PM
failsafe's Avatar
failsafe
....for your health
I know quite a few people running 9.5 on the front w/ 10.5 on the rear. This setup requires you to roll the rear fenders but I don't believe there is any problem with the fronts- you should be fine running 9 on the front.
