How will these look
Old Jul 8, 2007 | 01:44 PM
willyd6869's Avatar
willyd6869
Default How will these look
I am looking at a pair of wheels that are 18x9 +30 front, and 18x10 +30 rear...will these fit pretty flush?
Old Jul 8, 2007 | 01:53 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
8.5" + 10 in the front is pretty flush, so 9" +15 to +18 wold be flush. Rear will look about the same as the front.
I think you could go a little more aggressive but you should at least look better then stock and not have to worry about rubbing.
Old Jul 8, 2007 | 02:10 PM
LanceKA-T's Avatar
LanceKA-T
That **** is weak *****, what size tire do you want to run? This should be your determining factor on wheel choice. Take Bradley's for reference, a 245/40 all around with 18x9.5 +12 in the front and 18x9.5 -3 in the rear and still has some room out back.
You shoud deffinately come talk to Bradley, Kim or I before you buy wheels.
You could probably run let's say a 18x9 +5 or 0 in the front and 18x10 +0 would be around as flush as Bradley.
Almost all the people on my350z.com run decent sizes but know one pushes the limit.
Old Jul 8, 2007 | 02:21 PM
weak 350z's Avatar
weak 350z
The 06 track wheels are that offset. 18x9 +30 and 19x10 +30.
Old Jul 9, 2007 | 11:50 AM
chewychew's Avatar
chewychew
not flush at all
