Camber Problem WTF!
Old Jul 18, 2007 | 05:07 PM
pss350z's Avatar
pss350z
Default Camber Problem WTF!
I took my Z to an alignment shop about a month ago and had everything corrected and brought back to spec or as close to as possible after I had lowered it. Today I'm driving and notice as I'm going straight the steering wheel is a couple degrees to the right, WTF? Got home and took a look at the rears and noticed the camber to be alot more significant on one side compared to the other. I parked my car in the garage and took a 24" solid square to the rear wheels and sure enough the one side has 5/8" more gap at the top of the tire than the other. Is it possible that the camber adjustment got loose and got thrown WAY out of wack?
Edit:
Went under car and found that the excentric bolt on one side is giving max - camber and the other side is giving max + camber. And the bolt is loose! What a bunch of monkies. This place was supposed to be the best in the area.
Old Jul 18, 2007 | 07:14 PM
skeet96707's Avatar
skeet96707
The place you went to did they use the laser alignment rack. Or did they just eyeball it.
Old Jul 18, 2007 | 07:19 PM
saberphx's Avatar
saberphx
haha nice
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
