Help with the tire size please
Originally Posted by MethodRN
Oh yeah, I haven't had issues w/ VDC slipping w/ this set-up. Also even w/ hard cornering, I have no rubbing issues.
255/35 and 285/35 sounds good.
You guys have anyone told you that this set up is going to screw the car's calculation on miledge and Navi's calculation on distance?
Originally Posted by gambino
damn, so i will likely rub with 295 or even 285 with my +24 rears?
Originally Posted by 1nate7
I rubbed under hard cornering with a 285/35 on a 10" +25. I am lowered about 1.2 inches in the rear. I'd stick with a 275/35 unless you are willing to roll the fender in which case you could probably get a 295/30. Either way a 255/35 front is what I would go with.
