moving wheels from rear to front?
Old Aug 29, 2007 | 09:41 AM
playa6tnine's Avatar
playa6tnine
Default moving wheels from rear to front?
I have 19" Volk GT-V's in a 8.5" and 9.5" staggered set up.
Would it work if i was to move the rear 19"x9.5" (+24 offset) wheels to the front, and get 19"x10.5" wheels for rears?
i'm not sure if the +24 offset would be good for the front. like if it will be too deep or just wont handle right.
attached are pics of rear wheels.
Attached Thumbnails moving wheels from rear to front?-att46441.jpg   moving wheels from rear to front?-z2.jpg
Old Aug 29, 2007 | 10:09 AM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
ummm I think you shouldnt do it and ur gonna get flamed REALLY BAD!! GL
Old Aug 29, 2007 | 10:14 AM
iStan's Avatar
iStan
ZR
Old Aug 29, 2007 | 10:25 AM
SpeedRcr's Avatar
SpeedRcr
why would he get flamed for moving the rears to the front and getting new rears??? yes you can do that, just test fit it and turn wheel to wheel to double check but you should not have any issues
Old Aug 29, 2007 | 10:30 AM
2004Black350z
Exhaust Whore
I mean people on this webiste search threads just 2 flame. I gave u my advice like u asked. Take it or leave it
Old Aug 29, 2007 | 10:32 AM
iStan's Avatar
iStan
ZR
^ I am still trying to figure out exactly why he should get flamed? Do 24 Offsets not work? Is that a Rim Faux Pas?
Old Aug 29, 2007 | 10:33 AM
2004Black350z
Exhaust Whore
idk why he would either. Im saying people on here are dicks. Jeez
Old Aug 29, 2007 | 10:52 AM
1nate7's Avatar
1nate7
9.5 +24 is a low disk wheel with maximum lip. It might not clear your brakes in front, especially if you have Brembos. Otherwise there shouldn't be any fitment issue with a 9.5 +24.
Old Aug 29, 2007 | 11:51 AM
playa6tnine
thanks for the help guys.
what are average offsets for a 9.5 wheel up front with an aggresive lip? just wondering what my offsets are compared to what they should be
Old Aug 29, 2007 | 12:21 PM
1nate7's Avatar
1nate7
The offset is fine. Like I said, your biggest issue is brake clearance since +24 is a low pad fitment. Look at the chart below:
Most people without Brembos pick mid pad (most common is 9.5" is +27) for the front and a low pad for the rear. Pull a rear and test fit it on the front. If it will clear the brakes then it will work fine.
Old Aug 29, 2007 | 12:27 PM
playa6tnine
hey man thanks for the info and the chart!
Old Aug 29, 2007 | 12:33 PM
raycs7's Avatar
raycs7
OEM use 9.0 with 30 offset on the GT and Nismo.
I know 9.5 with 35 offset will touch on the inside.
It will be close but may be ok..
Old Aug 29, 2007 | 01:18 PM
redlude97's Avatar
redlude97
You could also run a 10mm spacer for added caliper clearance, it would put you in the middle of a mid and high pad clearance for a BBK.
Old Aug 29, 2007 | 02:19 PM
Amiricanmade's Avatar
Amiricanmade
...i think you're going to get flamed for your comment.
issyz
Jul 2, 2017 03:04 PM
hulkout
Apr 28, 2017 09:00 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
