Tire sizing question... hmmm...
Old Sep 14, 2007 | 03:21 AM
dkmesa350z's Avatar
dkmesa350z
I can't say whether or not it will bug out VDC, but isn't the recommended wheel for 295/35 like 10-11.5? If not, I would do 255/40 in the front, so the tire isn't so damn short (255/35 will be pretty small). If you end up having to get the 275/35, just make sure you go with 245/40 or 255/35 fronts, so they aren't taller than the rears. Oh and the series of the tire is a ratio sidewall height to width, not the actual height of the sidewall (if you notice the height of most 40 series sidewalls is not 4 cm)
Old Sep 14, 2007 | 06:31 AM
taurran's Avatar
taurran
Yeah, I know. I know many people that run even bigger tires on 9.5" wheels. I've seen 315 DR's on nismo lmgt4's, so I know the 295 will work just fine. I sat the wheel on the 295 and it looked good.
As I said above, the 275's are on nationwide backorder from BF Goodrich. There's no shipping date on them and not even a promise that they'll continue making them in the future. For that reason, I'm going with the 295 rears. There is no such thing as a 285/35/18 drag radial.
I'm mainly concerned about the overall diameter of the tire. Width wise, I've got about the same difference in width on my street tires that I'm currently running with no issues.
My concern now about diameter is that the 265/35/18's are ony .3in taller than the 255/35/18's. This will still be a big difference with the rears. The 255/40/18's are 26in in diameter and the 295/35/18's are 26.2in in diameter. This seems to be the most well sized set to me.
Old Sep 14, 2007 | 06:35 AM
taurran's Avatar
taurran
Originally Posted by StreetOC192
taurran, I know you wouldn't want a smaller rear, but wouldn't the sizing be better if you went with a 285/35 or even 275/35 in the rear and left the front as-is (255/35)? I wouldn't think you would want to increase your sidewall on the fronts.
Not a possiblity, note the 275's are indefinitely out of stock so my only option is 295.
Old Sep 14, 2007 | 11:44 AM
terrasmak's Avatar
Lets break it down really easy and simple , the stock tire are a 225/45 and 245/45 . If you nitice the aspect ratio is the same and a 20mm difference between the two. When you get you new tires keep the same aspect ratio and have a 20mm difference between them. ITS JUST THAT EASY , and everything with be the proper.
Old Sep 14, 2007 | 08:03 PM
taurran's Avatar
taurran
Having a 20mm difference at wider tire levels wouldn't be the same ratio.
Old Sep 14, 2007 | 11:32 PM
redlude97's Avatar
redlude97
doubling that distance without doubling the width of the tires isn't the same ratio either
Old Sep 17, 2007 | 03:22 PM
taurran's Avatar
taurran
Not sure what that means exactly, but per the 225/245 ratio, it would require a 270.9 wide tire for a 295 rear. I guess the closest it would be would be a 265/35. The only concern I have is that there is still a .9in difference in diameter between the two.
Old Sep 17, 2007 | 03:51 PM
redlude97's Avatar
redlude97
There is suppose to be a height stagger, 265 is much better choice paired with the 295 than the 255. The most common combinations here are 245/275, and 255/285, 30mm width stagger seems to work well for most people, and when people deviate its usually to run less width stagger, not more. This is comming from someone running a 40mm stagger also, next time i'll be going to 255/265 in the front paired with a 285 rear
Old Sep 17, 2007 | 03:52 PM
roncfpz's Avatar
roncfpz
+1.........that's perfect!
Old Sep 17, 2007 | 07:41 PM
Chad68's Avatar
Chad68
Ok, well, I've come to the conclusion that I absolutely suck at buying the properly sized tires. I just recieved a set of four tires, two front BFG KDW2 and two rear BFG Drag Radials for my 18" wheels. Here are the specs:
Front: 18x9.5, 255/35/18 KDW2
Rear: 18x9.5, 295/35/18 DR
The big issue is the overall diameter of tires. I was going to get the 275 DR's for the back, and change my mind at the last minute because the size was on backorder for months. The 295's are almost an inch larger in diameter.
So, the 255/35 fronts only have a diameter of 25", and the rears have a diameter of 26.2". If I were to order the 40mm sidewall in front, they would have a 26" diameter.
My question is - am I ok with that large of a difference in diamter of tires between the front/rear, or should I go ahead and send these back and get the 40 series tires up front?
Thanks in advance.
If you just switch to a 245/40 up front (instead of your 255/35's) your 295 rears would be just a tiny bit larger than your fronts, instead of 1.2" and your car should corner a ton better.
When my 305's wear out I'm going to run 295/30/19's with my 245/35/19 fronts. Should make my car corner better since there will be less diff in diameters.
sales@czp
Sep 23, 2019 03:30 PM
