help on offset.....
Old Oct 17, 2007 | 01:47 PM
NumberOneZ's Avatar
NumberOneZ
Default help on offset.....
ok I have been lookin at the weds sa70's. I like em a lot!!! what offset should I go with? obviously I am gettin the 18x10's in the back so those I have to get +18. which is fine if I have to roll the rear fender. Now on the front I may be goin with a 10mm wider front fender so what offset should I get?
Travis
Old Oct 17, 2007 | 04:12 PM
Use a offset calculator to compare your current wheels to the new wheels. With the new dimensions, check the car with a tape. Do you clear the suspension, brakes calipers and fenders? Reference: http://www.1010tires.com/WheelOffsetCalculator.asp
Old Oct 17, 2007 | 04:33 PM
NumberOneZ's Avatar
NumberOneZ
so you have the wedssport sa70's? what offset did you use and do u have anymore pics?
Old Oct 17, 2007 | 05:36 PM
badkarma85's Avatar
badkarma85
what's the width of the front wheels?
if 9.0 then approximately +15
if 9.5 then approximately +22
Old Oct 17, 2007 | 06:50 PM
My wheels are 18x8 so offset is simple.
https://my350z.com/forum/showpost.ph...&postcount=131
Old Oct 18, 2007 | 05:03 AM
NumberOneZ's Avatar
NumberOneZ
alright thanks man! i am thinkin about goin with the +32 on the front and not worry about the wider front fender. cuz i want 18x9 in the front and 18x10 on the back.
