rear spacers only
Old Oct 22, 2007 | 01:11 PM
Ilov350ZEE's Avatar
Ilov350ZEE
Default rear spacers only
I have an 06 w/ 15kmiles lowered on Tanabe GF210 still on stock struts. Im planning on putting Project kics 25 mm spacer on the rear and none on the front, whats the down side on doing this handling wise??
Old Oct 22, 2007 | 01:12 PM
iStan's Avatar
iStan
ZR
With the drop, you may run into some rubbing.
You'll also still have that massive gap in the front.
Old Oct 22, 2007 | 01:29 PM
redlude97's Avatar
redlude97
The car will look ackward with such a discrepency in stance, why would you want to do that?
Old Oct 22, 2007 | 05:48 PM
Gooey's Avatar
Gooey
put 25mm spacers all around and itll look beautiful...
Old Oct 22, 2007 | 05:56 PM
Equinox's Avatar
Equinox
Understeer, understeer, understeer!
Old Oct 22, 2007 | 07:30 PM
paulbk's Avatar
paulbk
will this cause rubbing?
Old Oct 22, 2007 | 07:54 PM
ADMAN's Avatar
ADMAN
+1 on the understeer. It will be pretty bad.
Old Oct 3, 2008 | 03:28 PM
avandss's Avatar
avandss
why will it understeer?
Old Oct 3, 2008 | 03:37 PM
moforeynolds's Avatar
moforeynolds
I currently have my front 15mm spacers off, but am still running my 25mm rears. Stock wheels with Sportline drop (slightly lower than the GF210s). Rolled rear fenders. No noticable understeer at all, and it looks fine. Not preferable, but fine; I took the front spacers off for a friend to see what a 15mm looks like compared to a 25mm, and have just been lazy about putting them back on.
But like I said, absolutely no noticable understeer.
Old Oct 8, 2008 | 10:24 PM
avandss's Avatar
avandss
i have 25mm spacers in the back, with gf210, with your rolled fenders do you think you have enough sapce to run 265's?
