Water spots on Volk's anodized lip.....Damn Rays!
Old Nov 10, 2007 | 08:49 PM
hiz-n-herz's Avatar
hiz-n-herz
Originally Posted by ___DJK___
Yes they are polished and clear coated.
You can do more damage washing the rims than drying them. If you catch a piece of gravel in your sponge, washcloth, etc, its real easy to drag it across the lip without knowing and creating hairline scratches. Once the wheel is totally clean a microfiber towel isn't going to do any damage. I buff mine to a nice shine and on occasion put some Zaino on them inside and out.
Cool. I'll give them like 10 coats of wax before I even put them on the car...
Can I pull off that blue clear tape that protects the outside edge of the lip? Or do they leave that on while mounting the tires?
I gotta find somewhere to install tires without scratching the rims. America's tire co ALWAYS effed up the rims on my M3. dunno if it's cause they are busy and in a hurry? They won't be touching these rims...
I am super-**** about washing my car. If I drop a mitt, which I have not done for a while, I set it aside and use a back-up mitt and then wash the hell out of the one I dropped when I'm done.
Old Nov 10, 2007 | 09:22 PM
pinoiZ's Avatar
pinoiZ
Originally Posted by MIVsupra93-2JZ
Holy sh*t, it worked!! I actually thought of this before I read your response. If dirty water is the cause of the mineral/calcium build up on the lip, then figured clean water, in my case purified water would do the trick....and it did.
I think the key here though, is that the wheel has to be very cool to the touch. For some reason, it take less effort to get rid of the dried water spot when its cool opposed to warm. I basically take a clean microfiber cloth and soak it with a bottle of purified water and then use it to wipe the lip.Don't forget to ring the cloth of any access water before you wipe the lip. The first thing you see is some water smears and fogs, but wait a couple of second and they will disappear along with the water spot! The temp here is 60 degree so that might help. The vinegar+water helped but it took me several hard wipes and it can get sticky.
I was surprised and relieved. Now no more water spots on my rims.
I have another advice. Never wipe your lip with any kind of dry cloth. Even with microfiber, the lip scratches very easily. So that means, I don't recommend waxing them.
i know you pay high dollar on that rim but all i can isay even though how much you take care of ur rims it will get scratches. the only way not to scratch ur rims is dont use the car.
Old Nov 10, 2007 | 10:12 PM
___DJK___'s Avatar
___DJK___
Yeah I polished mine inside and out before the tires were mounted with a coat of zaino. Makes cleaning easier and helps them resist water spots.
I left mine on but I dunno if they removed it before or after mounting the tires.
Old Nov 10, 2007 | 10:14 PM
___DJK___'s Avatar
___DJK___
Haha, so true, you can be super careful and will get scratches no matter what!
Old Nov 11, 2007 | 08:53 AM
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
Wheelwax.com
Took all my water spots when ever I had them on my GT-C's
Old Nov 12, 2007 | 07:51 PM
ACI318's Avatar
ACI318
Please leave that blue plastic on until they are mounted. Take the advice of someone who puts on wheels for a living. It has saved me before from scratching a wheel when mounting it.
Old Nov 12, 2007 | 08:15 PM
ALO8's Avatar
ALO8
can i apply car wax to time attacks b4 i mount also?
Old Apr 22, 2019 | 10:45 PM
Lucky736's Avatar
Lucky736
Tried a 50-50 of water and white vinegar. No luck.
Yes I realize this is an old thread but I am certain others are dealing with it.
Old Apr 23, 2019 | 10:38 AM
saywat?'s Avatar
saywat?
meguairs water spot removal works great for me. ive never had to use them on my volks when i had them but it worked on the windows. i dont see why not on the volk barrels
Old Apr 23, 2019 | 05:56 PM
travlee's Avatar
travlee
Master
After you get the spots out. Seal them with something
Old Apr 23, 2019 | 06:02 PM
saywat?'s Avatar
saywat?
car wax should be good enough. thats what i used
Old Apr 23, 2019 | 06:23 PM
travlee's Avatar
travlee
Master
I opticoated my vette wheels, when I get around to doing paint correction on my cadi, I am going to ceramic coat my wheels at the same time
Old Apr 23, 2019 | 06:47 PM
Lucky736's Avatar
Lucky736
Thanks for the good advice. Going to give a few of the suggestions a go and report back. I hope this has been helpful to some others as well, I know I brought it way back up. Lol.
350z82
Oct 1, 2015 06:25 PM
