Aggressive Wheels and Stretched Tires....Welcome
Old Feb 17, 2016 | 08:16 PM
  #23821
IIQuickSilverII's Avatar
IIQuickSilverII
Originally Posted by Battleship350z
Nope its paint, looks a little different under LEDs
Ah, cool Dood, was talking about shine, either way the blue Got me confused, that just additional vinyl then?
I like stance.. I know you said you like the camber stance without doing anything, but Fronts feel a bit more out/tight on the fender than rears, maybe cause of camber very stretch look, but I'd try to straighten the camber on rears out a bit more... So stagger is a bit clearer
Old Feb 17, 2016 | 08:19 PM
  #23822
Battleship350z's Avatar
Battleship350z
Has anyone experienced this?!? My tire is slowly losing air by the bead but it appears to stop at 30 psi.. If I pull the tire towards the face of wheel it also seals it. Should I get like 50 psi in it and than go down to 35-40?
Old Feb 17, 2016 | 08:28 PM
  #23823
IIQuickSilverII
Originally Posted by jdmfetish
what rear deck lid spoiler do you have on your car
It's the Vertex in CF maing.
From experience when you ask taste majority that go for salad bar wings for show purposes are younger kids, and older go for cleaner look for duckbill look.
I don't dislike SBS wings, Imo they below on true track cars or very aggressive looks, but really I prefer clear look following body lines over fanboy looks.
Personal taste on duckbills top 3:
1-Stardast
2-Vertex
3-Webber or RB
For wings
1-Power Enterprise
2-Voltex
3-Garage Mack
Old Feb 18, 2016 | 07:33 AM
  #23824
irishguy0224's Avatar
irishguy0224
Sounds like whoever mounted your tires didn't use bead sealant.
Old Feb 18, 2016 | 07:58 AM
  #23825
HRMoneyPit's Avatar
HRMoneyPit
No wrong
Bead sealant is not needed. Most likely they tore your bead when installing. If not, then bead sealant but that's last resort
Old Feb 18, 2016 | 08:11 AM
  #23826
irishguy0224
Originally Posted by HRMoneyPit
No wrong
it isn't wrong lol. Bead sealant isn't needed all the time no, but it is a great way to make sure everything seals as it should. Why would it be a last resort?
Old Feb 18, 2016 | 10:07 AM
  #23827
Battleship350z
All of my other tires are sealed fine and after riding on the one that leaks for a day it still sits at 30 psi but when I go over 30 it leaks back down to 30
After another day it has dropped down to 14psi, attempted to air it up with a shitty gas station compressor and had no luck, hopefully will use a better one today, the tire looks like it has air and sits normally, I'll be searching for the leak today but I assume it's still the bead as it was before.
Old Mar 2, 2016 | 10:58 PM
  #23828
JuniorDeJesus's Avatar
JuniorDeJesus
Okay I'm having a little deciding on size tires wheels 18x10 and 18x11.5 I was thinking 225/35 F and 265/40 R looking to get a good stretched but nothing too aggressive....
What do you guys recommend?
Old Mar 3, 2016 | 05:26 AM
  #23829
jdmfetish's Avatar
jdmfetish
this is a 245-35 on an 11 " rear
so yours will be less stretched than that
Old Mar 3, 2016 | 05:28 AM
  #23830
jdmfetish's Avatar
jdmfetish
this is a 225-35 front on a 9.5" front
yours will be more stretched than that
Old Mar 3, 2016 | 07:26 AM
  #23831
irishguy0224
as soon as my tires come in i will post pics, but i am running a 225/35 on a 10.5 and a 245/35 on a 11.5
Old Mar 3, 2016 | 07:49 AM
  #23832
JuniorDeJesus
Default Thanks
Sick ride man! 👍🏼👍🏼 and thanks for the help I'll probably bump up the numbers a little in the front and down for the rears
Old Mar 3, 2016 | 07:51 AM
  #23833
JuniorDeJesus
Please upload them! I was thinking 235/225 fronts so I'll see how this looks
Old Mar 3, 2016 | 08:06 AM
  #23834
jdmfetish's Avatar
jdmfetish
if i was you I would do 235-35-18 on a 10" F & 265-35-18 11.5" R
but that is me
Old Mar 3, 2016 | 12:43 PM
  #23835
irishguy0224
i just realized i typed it wrong. I am doing 235/35 on the 10.5 and a 245/35 on the 11.5 these are 19's
Old Mar 5, 2016 | 06:17 AM
  #23836
Battleship350z
Here's a 235/35 on 10.5. I'd put a 255/35 on the 11.5 just so its evened out.
Old Mar 10, 2016 | 04:33 PM
  #23837
joshewahicks's Avatar
joshewahicks
New to the forums but here are my wheels
18x10.5 (f) 225/40/18
18x11.5 (r) 245/40/18
This is on stock camber and toe arms in the rear. I don't have any updated pictures but I have camber and toe arms on currently
Old Mar 11, 2016 | 08:00 AM
  #23838
jdmfetish's Avatar
jdmfetish
these are yours on the car, 10.5 front with 235-35 & 11.5 rear with what size tire, you put or you would put a 255-35 on the 11.5?
Old Mar 11, 2016 | 01:15 PM
  #23839
Battleship350z
Its my car but 10.5 235/35 is rear front is 9.5 with a 215/35 I say go 255/35 on 11.5 so that ur stretch is more even between the front and rear but thats my preference
Old Mar 11, 2016 | 03:17 PM
  #23840
joshewahicks
I was going to run a 35 side wall but I got those rear tires for free and the front for $50 brand new I couldn't pass it up
