Aggressive Wheels and Stretched Tires....Welcome
Old Nov 8, 2011 | 08:34 AM
  #18121
Waiz's Avatar
Waiz
^Thread merged
Old Nov 8, 2011 | 09:29 AM
  #18122
JBF's Avatar
JBF
coilovers, 245/225, and big ******* spacers
Old Nov 8, 2011 | 09:58 AM
  #18123
vex008's Avatar
vex008
Originally Posted by JeffJohnries
Looking to have a little bit of rim poke when I get my 19's...
They will be +12 offset...
My car is dropped on Sportlines.
Any help with tire size you guys can give would be GREAT!
I do not think I will get any stretch for a 245/275 setup.
can not help without wheel widths for fronts and rears.
F: 19 x ?
R: 19 x ?
Old Nov 8, 2011 | 02:42 PM
  #18124
saberphx's Avatar
saberphx
Originally Posted by zerostyle
your car looks |__________| wide lol
I don't get it? Are you being sarcastic or does my car really look wide? haha
Old Nov 8, 2011 | 03:32 PM
  #18125
-Trav-'s Avatar
-Trav-
My car is hardly considered low on Sportlines.
Fixed in bold..
Get coilovers first, otherwise it will look terrible.
Just do +22 9.5/10.5 with 245/275 if you plan to stick with sportlines.
Old Nov 8, 2011 | 09:51 PM
  #18126
Big_C's Avatar
Big_C
Did someone say ERM? My boy has a set.
19x11.5 -35
19x12.5 -35
IMG_9751 by Chris Minshall, on Flickr
Old Nov 8, 2011 | 10:39 PM
  #18127
nosurf2day's Avatar
nosurf2day
19x11.5 -35
19x12.5 -35
OMFG!!!
Is he selling those rims? The would look pure sex on my car! I am trying to complete my setup with suspension and rims. Since going widebody, I am seriously lacking. Went back to stock suspension since I wasn't sure how low the kit would be. Stock suspension would give me a baseline to work off of instead of going from the Tein springs I had.
Here is a pick now. Still trying to figure out, should i go bags to get it really low or go with a stiff suspension. This is not my DD so i dont have to worry about getting all over the place.
Unfortunately I am in Afghanistan right now so I couldn't do anything anyway.
Old Nov 8, 2011 | 11:55 PM
  #18128
Max-G's Avatar
Max-G
19x11.5 -35
19x12.5 -35
hmmmmm how big are his tires? looks awkwardly high. tucking rim would make it look 18773x nicer.
Old Nov 9, 2011 | 12:44 AM
  #18129
blitzkrgct9a's Avatar
blitzkrgct9a
Originally Posted by Amoney47
thats sick!
Old Nov 9, 2011 | 12:45 PM
  #18130
shaddy-z.'s Avatar
shaddy-z.
This is probably a noob question but how much PSI do you put in your tires? I have 18x10.5 245/40 all the way around and the tire says 51 PSI is max. Right now I have 42 PSI for the rear and 40 PSI for the fronts. Should I go higher?
Old Nov 9, 2011 | 01:23 PM
  #18131
futureowner's Avatar
futureowner
Futrama Fry voice.... Not sure is serious or really sarcastic.
Wayyyy too PSi, check the side of your door should be somewhere around 35
Old Nov 9, 2011 | 01:45 PM
  #18132
KingBaby's Avatar
KingBaby
Hardest Setting
Even without stretching PSI is too high...
May be for cheap drifting but dangerous
Old Nov 9, 2011 | 01:46 PM
  #18133
shaddy-z.'s Avatar
shaddy-z.
I'm pretty sure OEM specs don't apply to stretched tires lol. I've read people running from 30 psi all the way up to 50.
Old Nov 9, 2011 | 01:55 PM
  #18134
Twenty4's Avatar
Twenty4
40 psi is fine. don't worry.
Old Nov 9, 2011 | 01:57 PM
  #18135
shaddy-z.'s Avatar
shaddy-z.
Are you sure its too high? Usually stretched tires need a higher PSI.. I searched the thread and read that Edafe runs 40-43 PSI all the way around usually. I mean my ride quality isn't bad at all I actually kind of like it after pumping them up. Not as much bounce as before.
Old Nov 9, 2011 | 02:11 PM
  #18136
alic4nte's Avatar
alic4nte
Stretched tires are different. 40-45 should be fine.
Old Nov 9, 2011 | 03:21 PM
  #18137
shaddy-z.'s Avatar
shaddy-z.
^ Thanks! Should I run the same all the way around? I am running a square set up... but camber is obviously different. I'm doing 40/42
Old Nov 9, 2011 | 03:22 PM
  #18138
JeffJohnries's Avatar
JeffJohnries
Originally Posted by -Trav-
Fixed in bold..
Thanks for such a helpful post... I understand it will be hardly low... I didn't post that in here hence the "thread merged" post under mine...
Also here is a photo of +12 on sportlines...
Not so sure of it looking terrible...
*also sorry for posting this photo in here, Just proving a point... This car is not nearly low enough to deserve a post here...
Attached Thumbnails Aggressive Wheels and Stretched Tires....Welcome-in-yoface.jpg
Old Nov 9, 2011 | 03:45 PM
  #18139
-Trav-'s Avatar
-Trav-
Your picture proves nothing. Nice looking car, but wheel fitment is non existent.
With springs a fatter tire setup would suit you better than stretch. Your call at the end of the day, but you will not achieve proper fitment (in this thread) without coilovers.
I only speak from experience, as I own the same springs.
Old Nov 9, 2011 | 04:03 PM
  #18140
JeffJohnries
What tire size do you think is on the car above?
