I guess I will go ahead and try to drill the holes. Not like it's going to get any worse lol. Nice stance to everybody on this page. Replacing all my bushings and getting realigned so hopefully I will run much less camber Really starting to like what everybody's doing. A great balance of form and function. Nothing crazy with stupid camber. I'm aiming for that :P
Man it was hard for me to drill holes in mine also, but i went ahead and did it. My whole headlights had condensation in it. I drilled 6 small holes on mine. Clearly dont drill them in the back because water will shoot back in them... I drilled mine in the front on the bottom.
Alright i trying to decide what spring rate i should go with. I have stance gr+ true type and im about to go really low. The springs i have now are 12k/6k. What are some of you guys running? I was thinking about doing 16/10k?? Im just tired of scraping the frame and im not even as low as i want to be. Im about to order springs in a day or so.
yes unfortunately... but my wheels werent damaged like minty's. in my case wheel just came off cause of a careless mistake. just had to replace my fender and no other damages thank god.
How deep were the holes? Just enough to penetrate the plastic? I don't want to drill enough to be able to tell from the outside lol. I think I'll try it with the smallest drill bit I have.
Do you want me to take pics of mine? Im not talking about drilling them in the clear part of the headlight... Take you bumper off. Look straight at the headlight now go underneath it.. I drilled mine in the black plastic as close to the front of the headlight as i could. When i mean front i mean close to the bumper and UNDERNEATH the headlight. As soon as you drill some holes you will see water come out of it. I drilled 6 small holes in each. One hole will take a while for it to all clear up cause i started with 2. If you want a picture of mine i will take one today.
