Perfect that looks great jd714! Your wheels are the same exact specs just a half inch wider on all four wheels so it would look somewhat similar except my car is pikes peak white. So how hard was it to make it fit? Is it necessary to run a 215 to make it clear in the front or could you run a 225 and would you change anything about your tire setup the second time around?
Also what kinda camber are you having to run all around to make it work cause i just have coilovers on natural camber right now and im wondering if i will need to buy front upper a-arms and rear camber links or can just make it work without them?
Thanks again guys for all your replys! This helps a ton before i go and spend a lot of money lol
thanks man...im running -7 camber on the rear and im not sure on the front coz its natural camber....and yea you'll need a rear camber arms, rolled/cut fenders to make it fit..and for the tire sizes you can run 225 if u want but you will need to pull ur front fender to make it clear i say just go with 215/35 FEDERALS
Awesome ill probably run 215's then if i can just run natural camber up front. Now did you roll or cut your rear fenders and do you think those 245's work best in rear as well or do you think a 235 would look ok too so i wouldnt have to run as much negative camber? And last, why FEDERALS over any other tire? Im running Hankook Evo12's right now.. Thanks man you've helped a ton already!
heres a couple of iphone shots from an hour ago, im just plain stuck on my powdercoating decision... dont know what color combo to do. Gonna go with 235's up front and push them out to atleast -3 in the rear.
my fenders are cut and i think 245 work best and it also depends on the brand...right now im on FALKEN 452...i picked federals because theyre cheap lol
Woord lol well if i end up getting the wheels ill be sure to post up pics when im done thanks bro!
