What Offsets Are You Running With Your Volks?
Originally Posted by AlvinHuyN
Volk GTS 19x9.5 +28/ 19x10.5+30 (5 months ago)
Volk SF Challenges 19x9.5 +23/ 19x10.5 +24 (3 months ago)
Now onto Works with much more aggressive width and offsets.
Hey Alvin, any pics of your SF Challenges set up?
Originally Posted by 350z-900whp
what offset should i run on 18sX10 in order to run 305s+ tires !! if possible
Originally Posted by badkarma85
for 9.5/10.5 widths, and offsets under +20, do you guys need to roll your fenders?
Originally Posted by alan86
does 19x10.5 +18 rub without fender rolling? also dropped on gf210's
Originally Posted by Alberto
+22
The +23 will look great, ther +28 is too far in for the front IMO-weaksauce
I've had:
Volk LE37t 19x8.5 +24 /19x9.5 +30 in Gunmetal
Volk GT-V 19x9.5 +24 / 19x10.5 +30 in RMC
Volk SF-Challenge 19x9.5 +23 / 19x10.5 +23 in Gunmetal
Ray's G-Games 99b 19x9.5 +22 /19x10.5 +22 in Grey
Volk SF-Challenge 19x9.5 +23 / 19x10.5 +26 in Diamond Black
Volk GT-V 19x9.5 +24 / 19x10.5 +30 in Titanium Gunmetal
Volk GT-S 19x9.5 +28 / 19x10.5 +30 in Gloss Black
Current is, by far, the best fitment yet:
Volk GT-S 19x9.5 +17 / 19x10.5 +18 in Diamond Black
It will rub, on a 10.5" without running excessive camber and a really stretched tire, the max I have found you can run is about a +28, maybe down to a +25. I know that once you get to +23, or lower, it is almost 100% that it will rub without fender rolling.. depending on camber and tire size though
so running the above setup will require fender rolling in the rears only or both?
tires are 255/35/19 and 275/35/19
Originally Posted by dhwang80
sf challenge 19x9.5 +28/ 19x10.5 +23
your front fenders are basically rolled from the factory. You can't do much in terms of "rolling" them... you could pull them, but will not be needed up front with those offsets. Your rears will most likely need a slight roll. Your tires will be fairly stretched which will work in your favor as far as fitment and clearance is concerned. That said, in my experience, once you move lower than a +25 offset on a 10.5" wheel, you more likely than not need to roll your fenders
Originally Posted by Triple8Sol
I've had:
