so what size tires do i need with these
Old Dec 13, 2007 | 07:24 PM
III's Avatar
III
Default so what size tires do i need with these
Front Wheels are 19x8.5 w/+20 offset and rear are 19x10 w/+19 offset.
Old Dec 13, 2007 | 07:48 PM
Do not check the OEM tire width for a 8.5-inch wheel. Do not check the tire forum and see what width members are running on a 10-inch wheel.
Do not use a tire calculator to compare the OEM tire heights to your set-up.
Do not check the overall tire height to insure proper operation of VDC.
Let someone do it for your.
Old Dec 13, 2007 | 08:00 PM
henry j's Avatar
henry j
loll ^ exactly wat i woulda done
Old Dec 14, 2007 | 04:56 PM
Chad68's Avatar
Chad68
I would go with 245/35 and 295/30
BUT
With that rear offset Your rears would probably rub if lowered, so you would have to probably go with a 285 or 275.
245/35 and 275/35 would work but your rears might be stretched a little more than the front.
Old Dec 14, 2007 | 09:42 PM
VIZAGE's Avatar
VIZAGE
I'd say 245/35 and a 285/35. And with that tire size and offset, you can easily sport a 1" drop (fenders rolled) and -1 camber.
sales@czp
Sep 23, 2019 03:30 PM
