Tire Rotation
Old Jan 29, 2008 | 07:11 PM
350ziggy's Avatar
350ziggy
Default Tire Rotation
Hello to all,
I have an 06 enthu with 18 stock wheels and tires. I had a question about rotating the tires. I checked to see if they are directional, but they are not. I was wondering if there will be a problem rotating them that yall might know of. Just want to make sure that I do the right thing so that I dont mess anything up. Sorry but I am new to sports cars. Just being cautious, thats all.
Thanks in advance
Old Jan 29, 2008 | 07:14 PM
dutchboy350Z's Avatar
dutchboy350Z
Finally some go
Staggered Tires = You can't rotate them.
Old Jan 29, 2008 | 08:03 PM
350ziggy's Avatar
350ziggy
ok, so thats the only way I would not be able to rotate them. Right?
Thanks dutchboy350z!
Old Jan 29, 2008 | 08:09 PM
350ZTheStandard's Avatar
350ZTheStandard
Not staggered from the factory??
Then you can remove the front pins with a 10MM wrench rotate from to front to back on the same sides. Are you sure they are not directional, because the front & rear tire sixes are usually different. They are not designed to be rotated.
Old Jan 30, 2008 | 06:45 PM
Swiffer's Avatar
Swiffer
The stock tires ARE directional. They are also different sizes, so you CANNOT rotate them.
Old Jan 30, 2008 | 06:52 PM
sofa king's Avatar
sofa king
+1
Old Jan 30, 2008 | 07:00 PM
ncdoc's Avatar
ncdoc
The RE050A's are not directional tires, but I don't believe they were available stock on the 06. Thus with these tires you could theoretically "rotate" the tires from side to side without unmounting them, although I don't know how much benefit this would be.
The only available "rotation" for your stockers would be to remove them from the rims and switch sides, if I remember they were initailly doing this for the tire feathering on the 03's.
ncdoc
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
