18x9.5 LMGT4
Old Feb 24, 2008 | 07:14 AM
blindfold's Avatar
blindfold
Default 18x9.5 LMGT4
Looking to use 18x9.5 +30 nismo LMGT4 in all four corners, would they fit in the front with a +30 offset to clear brembos? If they do, would tires with 275 width fit without rubbing? Thanks.
Old Feb 24, 2008 | 07:59 AM
1nate7's Avatar
1nate7
Yes and yes.
Old Feb 24, 2008 | 10:07 AM
Fairly Z's Avatar
Fairly Z
Why do you want to lose the staggered offset? Go with 9.5 front and 10.5 rear.
Old Feb 24, 2008 | 10:19 AM
jjellyneck's Avatar
jjellyneck
I also plan to go with 9.5 all around--for wider tie fitment on front. 10.5 on back would be nice, but don't want to spend $$ nor do I want the extra tire width and weight on the back.
Old Feb 24, 2008 | 03:26 PM
mthreat's Avatar
mthreat
I think 9.5 all around would be a perfect setup for the track. Run 265 tires in the front, and 265-285 in the rear (depending on your power).
I run 265 tires all around, but I have the 18x8.5 in the front so the tire is a tad wide for the rim. Sometimes I wish I had 9.5 rims in the front too.
Old Feb 24, 2008 | 06:23 PM
HyperSprite's Avatar
HyperSprite
Mad Scientist
I am running 275/35/18 F ~ 275/40/18 R on four Nismo LMGT4 9.5s over Brembo track brakes. No rubbing of any kind. I like it quite a bit.
There are some pics here if you want
http://www.hypersprite.com/auto/tech-z-010/
Old Feb 25, 2008 | 07:18 PM
ke0ki2k's Avatar
ke0ki2k
non-staggered ftw. arent many successfull JDM time attackers that use a staggered setup. although the M-workz Z is using staggered 315/295 i think...he kinda has to though with 560 whp. if youre N/A non-staggered 275/35 all around is all you need.
PLAYDIRTY
Oct 12, 2015 07:45 AM
Ganglio
Europe
Sep 26, 2015 07:06 PM
