06 front wheel spacer question
Old Mar 28, 2008 | 06:31 PM
luanta's Avatar
luanta
Default 06 front wheel spacer question
Hi everyone, newbie here. Please help. I have decided (due to financial reasons) to go with wheel spacers instead of new wheels. I purchased 20mm/25mm F/R respectively. These are hubcentric spacers with premounted studs. The rear fits great however, the front disc has a protruding screw to hold the disc on instead of a recessed screw. Has anyone been faced with this dilemma? Is there a recessed screw that is safe to use for the front disc that is flushed with the rotor? I really like the look of the wheels with the spacers however, I can't install the front until i resolve the protruding screw problem. Thank you.
Old Mar 28, 2008 | 06:34 PM
dutchboy350Z's Avatar
dutchboy350Z
Finally some go
I could be wrong but, remove screw and you're good to go. The screw is there to make sure some jack *** doesn't put the rear wheels on the front.
Old Mar 29, 2008 | 04:37 AM
tight350z's Avatar
tight350z
yep..just grab a socket and pull the screw/pin out and your set...
Old Mar 29, 2008 | 08:55 PM
luanta's Avatar
luanta
I thought that was a disc retaining screw but I guess I am wrong. Thank you very much guys. I will try that.
RiujinZero
Apr 16, 2021 11:31 AM
bcoffee20
Nov 19, 2015 06:39 PM
abarclay
South East Marketplace
Sep 21, 2015 01:55 PM
sherm
Sep 10, 2015 11:02 PM
