RIM SIZE QUESTION want 9.5"ALL THE WAY
hey guys, i'll probably get hammered for posting this, but i wanted to know if it was possible to put 18" 9.5" all the way around. i know our cars fit 9.5" in front and 10.5" in back, but can i put 9.5" on all wheels, so that i can rotate my tires or do you have to have a smaller wheel in front. thanks.;
So if I have VDC I can't get same size rims and tires? I was thinking of getting Axis Reverb 18x8.5 with 245-45-18 or 245-40-18 tires? Or should I stick with stock with 225-45-18 front and 245-45-18 rear?
Originally Posted by 07rdsterGT
You won't be able to rotate your tires. Even if you get the same size rims, which is fine, you HAVE to have different size tires or your VDC will go crazy.
https://my350z.com/forum/wheels-and-tires/203755-will-these-tires-work-with-my-vdc-enabled-car-read-here.html
Originally Posted by hgill
well my biggest thing is that i would like to be able to rotate my tires and save some money. i have a 03 Touring with VDC, and i run through tires quite fast. Question: if i ran 18" , 18.5 all around, will i be able to rotate them, and since they are only 18.5, will it affect my VDC.
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
Subarism
East Canada
Sep 23, 2015 06:22 PM
Subarism
East Canada
Sep 23, 2015 06:09 PM
