Alignment with Underinflated Tires
Old Jul 5, 2008 | 10:45 AM
dtoma_esq's Avatar
dtoma_esq
Default Alignment with Underinflated Tires
Can anyone tell me if underinflated tires (at least 3-4 psi below the recommended inflation pressure) would result in an improper alignment of the tires?
I had an alignment performed on new tires that were recently mounted, but the car is pulling to the right. I checked the tire pressure the next morning when the tires were cold and discovered that 3 of the tires were underinflated by at least 3-4psi from the recommended 35psi.
Any feedback would be much appreciated.
Old Jul 5, 2008 | 06:30 PM
terrasmak's Avatar
Actually it could slightly, but 3 psi isnt enought to matter.
Old Jul 5, 2008 | 08:30 PM
WhiskeyHotel's Avatar
WhiskeyHotel
I'm sure the folks that did the alignment would be glad to re-check it for you. Especially if you tell them it's pulling - regardless of the tire pressure.
ablaine
Nov 29, 2016 10:13 AM
Depravity
Oct 1, 2015 04:49 PM
