How much difference does 5 lbs make?
Old Jul 10, 2008 | 11:05 PM
350Zforlife's Avatar
350Zforlife
370Zforlife
Default How much difference does 5 lbs make?
well I was snooping around in the top 100 questions and found out that my rims are (17" oem base) 5 lb heavier than the stock track rims. If I were to found a good deal on a set of track rims, how much difference would that make? performance wise + turning/handling wise? 5 lb seems a lot IMO and I hope it's not wrong to assume my handling will get better as well due to light wheel....
17" base rims F: 17x7.5 = 23.26 lbs and R: 17x8.0 = 24.140 lbs
18" track rims F: 18x8.0 = 18.1 lbs and R: 18x8.5 = 18.62 lbs
Old Jul 10, 2008 | 11:17 PM
Gag83's Avatar
Gag83
5 lbs isnt really enough to make a difference u could feel.
Old Jul 10, 2008 | 11:21 PM
rickyislaZy's Avatar
rickyislaZy
I would say 5lbs on wheels would make a huge difference.
Old Jul 10, 2008 | 11:31 PM
Andy@Performance's Avatar
Andy@Performance
Performance Nissan
Correct. In terms of shaving off weight from rotational mass and inertia; it will make a signficant difference in acceleration. This concept applies not just to wheels but as a whole in vehicle dynamics. The theory is that for every 1 pound you shave off rotational mass, you gain a horsepower.
Old Jul 10, 2008 | 11:36 PM
black06z's Avatar
black06z
A total of 20lbs of weight savings=very noticeable difference.
Old Jul 11, 2008 | 12:07 AM
Gag83's Avatar
Gag83
o 5 lbs per wheel. yeah then 20 lbs would make a good difference on the wheels.
Old Jul 11, 2008 | 04:22 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
Old Jul 11, 2008 | 05:53 AM
baovboi's Avatar
baovboi
i think that every 5 lbs on the wheel you lose 1 hp
Old Jul 11, 2008 | 05:59 AM
Spork's Avatar
Spork
A pretty big difference.
Old Jul 11, 2008 | 06:22 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
the wheels are heavier, but so are the tires...so I'd bet the difference is less than 5 lbs, if different at all
Old Jul 11, 2008 | 07:09 AM
terrasmak's Avatar
??? if the wheels are heavier and the tires are heavier , the difference would be even more. Probably closer to 7 or 8 pounds per wheel and tire.
Old Jul 11, 2008 | 08:09 AM
SpoilsofWar's Avatar
SpoilsofWar
No, the 17" wheels are heavier then the 18" wheels. However, 18" tires are heavier then 17" tires.
Old Jul 11, 2008 | 08:35 AM
SniperHunter's Avatar
SniperHunter
Barely. I just looked up the OEM RE40 17s and 18s: only the 18'' 245/45 weighs 2 lbs more than the 17'' tire. That is assuming he picked up his track wheels with OEM Potenzas.
My suggestion would be to go with Pilot Sport 1s. Very light weight tire (5-7lbs lighter than Potenzas), with great performance.
Old Jul 11, 2008 | 08:38 AM
SpoilsofWar
I never said the difference was equal, I was just agreeing with Adam that the difference in weight between the 17's and 18's will be less once tires are factored in. Assuming same tire model on both wheels, of course.
If you want to get really technical, you also need to factor in that an 18" wheel will place more weight farther from the hub, which is undesireable.
Old Jul 11, 2008 | 08:54 AM
SniperHunter
I wasn't slighting you, just stating what the difference is.
Edit: For whatever it's worth, I felt a huge difference in acceleration after my Dunlop WinterSport's came off months ago. Same difference I felt when my OEM Potenzas were swapped for PS1s.
Old Jul 11, 2008 | 09:49 AM
gsazabi's Avatar
gsazabi
Not if you get the Michelin Pilot Sport PS2's. PS2s in even 19s STILL weight LESS than stock Potenzas in 17s
Old Jul 11, 2008 | 11:27 AM
z-u-later's Avatar
z-u-later
Having owned two sets of OEM 17" rims and a set of OEM 18" track rims, I can tell you that there's a huge difference. The track rims are much lighter -- I can feel the diffence on the street, and on the track (autocross & road course).
Old Jul 11, 2008 | 11:33 AM
z-u-later's Avatar
z-u-later
Well, not necessarily . . . my OEM 18" track setup is much lighter than my previous OEM 17" setup.
18" track rims + 18" Toyo RA-1s (245/40) < 17" stock rims + Hankook Z211(275/40)
So, it all depends on the size and tire brand.
Nexx's Avatar
Nexx
on a N/A car you will notice a difference.
Old Jul 11, 2008 | 11:41 AM
Every pound makes difference.
