offset experts help needed
Old Aug 28, 2008 | 04:24 AM
bluesi808's Avatar
bluesi808
Default offset experts help needed
5x114.3 PCD
20x9.5, -26mm ET, Hi-Disk
20x10, -32mm ET, Hi-Disk
would these fit on my 350?
Old Aug 28, 2008 | 04:35 AM
sry110's Avatar
sry110
I'm guessing you mean +26 and +32?
Also are you asking whether or not your tires will rub against your fenders, or whether the spokes will clear your brake calipers, or what? You'll need to give the tire size to answer the first question, and you'll need to give which brake calipers you are using for the second question.
If you post the specific wheels that you are considering, someone else with the same setup could have a chance to chime in.
Old Aug 28, 2008 | 05:02 AM
lgear080's Avatar
lgear080
We also need a manufacture and model...
info pls
Old Aug 28, 2008 | 06:09 AM
Motormouth's Avatar
Motormouth
^hahaha, yes yes we do
Old Aug 29, 2008 | 04:11 PM
bluesi808's Avatar
bluesi808
ame shallen mx. i have the non brembo setup and i just need to know if can drive with it on. don't car about rubbing when turning.
Old Aug 29, 2008 | 05:05 PM
rickyislaZy's Avatar
rickyislaZy
If it is really negative offset, it will fit but you will need a lot of excessive negative camber to sit under the wheel well.
If it is positive, then buy some spacers with it because it will not be flush enough.
Old Aug 29, 2008 | 07:16 PM
Triple8Sol's Avatar
Triple8Sol
Are they negative offset or positive? We need you to confirm this.
Old Aug 30, 2008 | 02:44 AM
bluesi808's Avatar
bluesi808
it's negative
Old Aug 30, 2008 | 02:46 AM
bluesi808's Avatar
bluesi808
http://honolulu.craigslist.org/oah/pts/776267330.html
Old Aug 30, 2008 | 02:51 AM
4thHorse's Avatar
4thHorse
Alot of camber, wide body and your good to go. I'll pass
Old Aug 30, 2008 | 02:54 AM
The offset is ridiculous.
Old Aug 30, 2008 | 03:04 AM
banshee's Avatar
banshee
Damn those are some bada$$ Previas... but jeez with that camber it makes it look like the studs are broken!!!
Old Aug 30, 2008 | 08:09 AM
nipponpower's Avatar
nipponpower
ok...are looking to run major dish?
if your going for bragging rights as far as offset, -32 and -26 that is pretty crazy, but on a high disk, you wont be getting much for the dish or stance
you said you have the non brembo Z, i would recommend going for something lower, if you look at www.ame-wheels.com they have the chart on the shallen MX line.
if you want the fat lip, i recommend a low disk and a slightly higher offset.
example: according to their spec sheet 10 wide, -3 offset, your looking at 141mm of dish (5inch range), but if you go with the specs you posted earlier, the rear dish will be under 100mm because of the high disk. and from what the spec sheet looks like the front might have more dish than the rear....?
the advantage of having a non brembo Z, is that you are able to run a crazy fitment, b/c you can run the super low disk/pad.
hope this helps a little, help out a fellow 808 Z.
pm me if you got any more questions
Old Aug 30, 2008 | 11:20 AM
bluesi808's Avatar
bluesi808
thanks appreciate the info.
Old Sep 3, 2008 | 10:10 AM
tHisZ_bFAST's Avatar
tHisZ_bFAST
"Do It....Do It."
Justin100
Nov 25, 2021 06:26 AM
sherm
Apr 11, 2020 05:21 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
