Need help with spacer or wheel sizes
Old Sep 10, 2008 | 06:43 AM
ANGEL71's Avatar
ANGEL71
Default Need help with spacer or wheel sizes
I'm about to put my rear flares on my Z, I could go with rear spacers. Right now I have 19 by 10 Piaa Super Rozza
MY question is if I do spacers for now, would it will be a problem later when I get the wheels.. will the wheel sit in the right place when I take off the spacer,
I plan to do 20 by 12.5 in the rear.. but I have to do spacer now so they could put my flares..
Old Sep 10, 2008 | 08:47 AM
terrasmak's Avatar
Offset specs kinda help.
Old Sep 10, 2008 | 08:51 AM
mikez97's Avatar
mikez97
offsets would help alot and so would the size of the spacer your putting on.
Old Sep 12, 2008 | 08:43 AM
ANGEL71's Avatar
ANGEL71
That's the thing on my PiAA wheels I have a big lip and i'm trying to get a bigger lip on the new wheels, I'm new to this don't know much about off set - or + off set that's the reason I need help. to get a bigger lip what off set I need?
Old Sep 12, 2008 | 03:50 PM
If you run spacers, and get different wheels, you can either keep the spacers on the car or not.
Old Sep 13, 2008 | 07:23 PM
ANGEL71's Avatar
ANGEL71
Ones my wheels come in I want to take off the spacer cause the wheels I'm getting are 20 by 12.5. I have 19 by 10 now what sizes spacer do I need to push out my wheel so it will fill the space I did the rear flares V3 on my Z just the rears.. I need to push my wheel out.. some one told me 15mm another person told me 25mm from Ichiba Hub Centric version 2..
Old Sep 13, 2008 | 07:50 PM
z33allme's Avatar
z33allme
Ok 19x10 is your wheel size, now what are your offsets?
Old Sep 15, 2008 | 02:31 PM
ANGEL71's Avatar
ANGEL71
Don't know I got the wheels uses, the ones that I have on there now. They are the PIAA SUPER ROZZA 2pc. for the non brembo Z.. I have a huge lip on the back but with the new flares it won't reach, that's why I need help for what sizes spacer I need to push the wheel out so it would be even with the flares..
I know I'm a idiot, I need (spacers for DUMMIES) book. I hope you can understand what I'm trying to do..
Old Sep 15, 2008 | 02:55 PM
jubes's Avatar
jubes
The specs would usually be posted on a tab within the wheel saying like "19x10 +18"
if I remember from a post by motormouth, 1" = 27.5mm... so if you're making up about 2 inches of lip would be a pretty considerable size spacer unless they are negative in offset. (negative pushes the face of the wheel towards the axel giving deeper lips)
burglapfd
Dec 6, 2020 01:04 PM
ablaine
Nov 29, 2016 10:13 AM
Depravity
Oct 1, 2015 04:49 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
