bigger tires + spacers?
Old Sep 14, 2008 | 03:36 PM
itsjoshufocker's Avatar
itsjoshufocker
Default bigger tires + spacers?
Just to start.. i've already searched and came across nothing.
First i was looking at spacers and found that i want a 25mm up front and 30mm in the rear. Recently, i discovered that i need new tires as well and im looking to upgrade to (on stock 17's):
R 255/45/17
F 245/45/17
i know that this combo works for our Z with stock rims.
but now i dont know if these size tires will rub with the spacers i am planning on getting. i may lower in the future is this works out now. so my question is, will 255/45/17 rub with a rim 17X8 +3 (33+ offset, 30mm spacer = +3 effective offset) in the rear and 245/45/17 rim 17x7.5 +8 front?
Old Sep 14, 2008 | 04:19 PM
All your numbers are just on paper at this point so it makes it difficult to give a firm yes or no.
Going from a 245 to a 255 mm tire you will need an additional 5 mm clearance inside the tire and 5 mm outside. If you have the clearance its a go.
Old Sep 14, 2008 | 04:27 PM
350zDex's Avatar
350zDex
I Thought About The Same Set-up Awhile Back But With The Cash Ur Gonna Spend On New Tires And Spacers You Could Use That To Get New Wheels!!! Thats What Im Doing Haha
Old Sep 14, 2008 | 06:31 PM
itsjoshufocker
haha i want to keep the stock look for a while longer (few years till i graduate) and make the big jump with new rims/tires later on. i'm just trying to update the look without making any major changes!
davidv - so since stock rear tires are 235, i would need 10mm additional space inside and out with 255 tires?
ablaine
Nov 29, 2016 10:13 AM
