People With Toyos Proxes TR1
Old Oct 21, 2008 | 11:33 AM
gennosuke1's Avatar
gennosuke1
Default People With Toyos Proxes TR1
I just got some new wheels and tires put on my car and was wondering if other people who have 19 inch wheels with Toyo Proxes TR1 lowered their car afterwards. The measurments for the tires are 245/35/19-front and 275/35/19-rear.
Their is not much gap between the fender and tire but on one side it appears bigger than the other in the rear. So i was wondering if i would lower it if there would be rubbing or not since the tires are huge...
If anyone has lowered their car afterwards and had no problems i would appreciate it if you can post pics along with what kind of springs/coilovers. If you havent lowered it after you put the tires on please speak up as well and maybe post some pics
Thanks
Old Oct 21, 2008 | 12:32 PM
sry110's Avatar
sry110
Totally depends on the offset of your wheel. My previous setup was Toyo T1R 275/35/19 on 19x10 wheel with +25 offset. There was plenty of room between the tire and the inner fender lip. I probably could have run 6 or 7 mm spacer without rubbing.
Also keep in mind that if you lower the car and do not install a camber correction kit, the lower ride height means more negative camber (i.e. the top of the tire will lean farther inward toward the car) which gives you more clearance, but decreases your tire life on the inner edge.
Post up offsets and we can get this figured out.
Old Oct 21, 2008 | 03:10 PM
350z-Jason's Avatar
350z-Jason
i have volks 19" 9.5/10.5 17/18 offset with the exact tire specs u put up.. i had to cut the fenders when i lowered.
Old Oct 21, 2008 | 07:18 PM
gennosuke1's Avatar
gennosuke1
ok my offsets are 25 in front and 22 in back
they are 8.5 wide in front and 9.5 in rear
thanks
Old Oct 23, 2008 | 07:32 AM
TiresDirect.net's Avatar
TiresDirect.net
FYI
We are currently running a forum special on that combo:
https://my350z.com/forum/wheels-tire...ombo-deal.html
Dave
www.TD4L.com
May 30, 2017 03:28 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Dymsi
Sep 29, 2015 11:32 AM
35reilly
Sep 28, 2015 07:42 AM
