TE37 +12 tires / camber help needed
Old Nov 6, 2008 | 10:33 AM
Jason333's Avatar
Jason333
hi
Default TE37 +12 tires / camber help needed
I am running a set of TE37 in 9.5 and 10.5 +12. The rear has a 19/30/295, rolled fenders, -2 degrees of camber, and pulled a little. The rear doesn't seem to rub. The front has a 255/35/19 that does rub. What camber / tire setup are people running with similar setups to keep it from rubbing. I'd like to not stretch the hell out of the front if possible. The car is dropped about an inch maybe a little more.
Old Nov 6, 2008 | 10:37 AM
Crom's Avatar
Crom
Run a 245/35 or a /30/ tire w/ a slight fender pull...
Old Nov 6, 2008 | 11:09 AM
Jason333's Avatar
Jason333
hi
Think arms + a little more camber as an option as well?
Old Nov 6, 2008 | 11:15 AM
Crom's Avatar
Crom
Yup..get some cusco's or spc's for the value..-2. + in the front will start to wear
the tires pretty unevenly...but it'll fit + handle a little better.
Old Nov 6, 2008 | 04:27 PM
st350z's Avatar
st350z
Sweeeet... what color TE37s did you get?
Any pictures yet?
Old Nov 6, 2008 | 05:24 PM
lgear080's Avatar
lgear080
35 series 245/275... Very nice. Good luck and shoot it.
No more white, I hope. Merc Silver? Hmmm. That would
look balr.
Old Nov 6, 2008 | 05:27 PM
Crom's Avatar
Crom
look balr.
There was a thread on here a while back w/ some guy w/ fully polished TE's...looked insane.
Old Nov 6, 2008 | 05:57 PM
Jason333's Avatar
Jason333
hi
They are black TE's on a black car. I will get pics once everything is as I want it to look.
Thanks for the help. I order A arms.
I don't drive the car a lot as it is a weekend warrior at best. Camber up front shouldn't be an issue around 2- 2.5
Old Nov 6, 2008 | 10:38 PM
itsjiggajames's Avatar
itsjiggajames
245/35/19 will definitely fit in the front..
Old Nov 7, 2008 | 04:21 AM
Jason333's Avatar
Jason333
hi
I don't to run a tire that small if i can help it.
Old Nov 7, 2008 | 09:30 AM
350zEEEEEgirl's Avatar
350zEEEEEgirl
I'm running 245/35/19 Nitto INVO's up front right now on my TE37 +17's
Old Nov 7, 2008 | 01:17 PM
lgear080's Avatar
lgear080
^flics of your setup.. pls..
crom - considering an rbc dip. apparently i have to wait for
a local shop to offer the service.
Old Nov 7, 2008 | 01:40 PM
M3ANMACHINE's Avatar
M3ANMACHINE
Here is picture with my old Yoko ES100's 245/35/19 before I put the 5mm spacers in the front, so it was a +22 then, but you get the idea. With the Invo's and spacers, it fill's out much better... I'll try to get more recent pics.
https://my350z.com/forum/members/350...ture583-a.html
Old Nov 7, 2008 | 03:01 PM
lgear080's Avatar
lgear080
I remember that car. Looks awesome. Basically one of the best combos out there.
Old Nov 7, 2008 | 04:29 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Jason, lower the car a little more, and run some more negative camber. -2.5 should do it...but even -3.0 if you can. That will eliminate any rubbing.
Lemme know if you still need arms....we have been using the SPC's lately, but I run the Cusco on my race car.
Old Nov 7, 2008 | 06:30 PM
OffsetZ33's Avatar
OffsetZ33
Ive got 9.5 +12 with another 3mm spacer (so +9) with 265/30/19s up front, camber is about -3 degrees and Im really low. I rarely rub my passenger side inner fender liner (with a passenger), on larger dips... never the drivers side. My passenger side sits just a tiny bit lower especially with a passenger in the car too.
Old Nov 7, 2008 | 11:59 PM
M3ANMACHINE
I would die running -3 deg. of camber!!! GOOD-BYE TIRES!!!
Old Nov 8, 2008 | 05:03 AM
Zridder19's Avatar
Zridder19
Camber that bish out. Tires can be replaced
Old Nov 10, 2008 | 08:00 AM
Jason333's Avatar
Jason333
hi
Gonna start at 2.2 and see where it goes. The only problem is getting the savages at the local tire alignment shop to not destroy my wheels...
DarkCreep
Oct 17, 2015 11:50 PM
emooheo
Oct 14, 2015 08:58 AM
PLAYDIRTY
Oct 12, 2015 07:45 AM
