What size spacer(s)?
I wanted some advice on what size spacers I should put on the rears and if I could possibly run a spacer in the front.....Right now I have 18 x 9.5 +12 Work CR Kais on 245 tires all around....the front sits fairly nice but the back deff needs a spacer. My question is can I put a spacer in the front without having to pull the fender or anything like that? (Can you safely pull the front fender without messing anything up?) If so what size? As for the rear....I know someone with 15mm spacers in the back with the CR Kais/stance coils/245 tires, but not sure if he is out as much as he can be.
FRONT
REAR
FRONT
REAR
