NEED HELP: will this wheel set up fit 350z
Old Nov 16, 2008 | 12:58 PM
Bho's Avatar
Bho
Default NEED HELP: will this wheel set up fit 350z
19x9+24 19x10+24 4&5x114.3 it is SSR Vienna. will it fit? is it an aggressive fitment because i want to go vip style with good stance and lip. any comments will be appreciated. thanks
Old Nov 16, 2008 | 01:16 PM
M3ANMACHINE's Avatar
M3ANMACHINE
It should fit very easily. Offset's are not aggressive at all. You'll need at least 15mm wider on both front and back if you want aggressive
Old Nov 16, 2008 | 01:23 PM
d1mon3k's Avatar
d1mon3k
yes you will need atleast half an inch wider wheels or atleast 15-16mm wider on your offsets
Old Nov 16, 2008 | 03:31 PM
Do not use a offset calculator and figure it out. Take someone else's word for it.
Old Nov 16, 2008 | 04:21 PM
Triple8Sol's Avatar
Triple8Sol
It will fit. Not even close to being aggressive.
Run 20mm spacers front/rear. At least 15mm if you want to be more conservative.
_koubie_
Sep 20, 2015 06:34 PM
VQA33
Wheels Tires
Sep 8, 2015 08:30 PM
