what is the WIDEST TIRE F/R possible???
Old Aug 18, 2003 | 07:04 PM
zoasis's Avatar
zoasis
Default what is the WIDEST TIRE F/R possible???
Whats the widest tires anyone has ran in the front/rear
I have a 275/40 in the front and rear on 17X9's but I think the sidewall is a bit tall on the 275/40's. I'm thinking of stepping up to 18X10.5-11 rear and 18X9.5 front. Can I run a 305/30/18 rear? And maybe a 285/30/18 front? I'll be running Hoosier R-compounds for autocross use only so I want the widest possible tires, I'll have custom rims made if I can't find any pre-made with the correct offsets.
Old Aug 18, 2003 | 07:41 PM
ares's Avatar
ares
Veteran
have to roll the fenders I would imagine...
but its possible
Old Aug 18, 2003 | 11:43 PM
zoasis's Avatar
zoasis
Can you roll the fenders professionally. I mean, to make it look like it was meant to be?
Old Aug 19, 2003 | 05:43 AM
havabooz's Avatar
havabooz
someone on this forum rolled his fenders (im sure there are more ppl)...anyway hes the only one that i actually talked to about it...i believe the thread that it was in was called "anyone go from 17's to 19's)...i found the thread...his name is karmamag..he has 10.5 in the back with a 295..im not sure if u can fit a 305
anyway....he did his own rolling (hes a pro)...PM him
here is the link to the thread
https://my350z.com/forum/showthread....hlight=fenders
Old Aug 19, 2003 | 03:23 PM
wadd3456's Avatar
wadd3456
There have been quite a few 305 folks. I had a picture on my desktop for almost a year ago of a Z with 11" wide rears with 305s and it was lowered.
Old Aug 19, 2003 | 06:48 PM
zoasis's Avatar
zoasis
thats damn good news. I'd like to go to 18X11 rears with 305/30/18 hoosiers and 285/30/18 fronts on some 18X9.5's or 10's.
Any idea on wheel selections that may have been used??
Old Aug 19, 2003 | 09:01 PM
blackZon19x10's Avatar
blackZon19x10
I WORK FOR DONZ WHEELZ IN NY. I HAVE A CUSTOM 2 PIECE WHEEL MADE THAT MY COMPANY IS GOING TO MASS PRODUCE. IT IS 20X11, REAR AND 20X9.5 FRONT. I AM RUNNING CONTINENTAL CONTI-2 255X35X20 AND 305X30X20 WITH A TEIN COOILOVER SYSTEM. CAR RIDE AND FEELS LIKE A DREAM. NO MODIFICATION AT ALL FOR TIRES. ABLE TO USE 335 WITH ROLL PROVIDED BY PIRELLI. ANY OTHER QUESTIONS, PM OR WRITE BACK AT DONZREP@AOL.COM.
Old Aug 19, 2003 | 10:11 PM
D'oh's Avatar
D'oh
If I recall, john350z also has rolled fenders. His looked stock and I couldn't tell until I felt underneath the wheel well. Basically they folded the flange that normally forms an approximate right angle with the body back until it made a 180 degree bend. From the outside it looked stock unless you really looked close at the apparent thickness of the sheetmetal around the opening.
-D'oh!
Old Aug 20, 2003 | 12:24 AM
KarmaMag's Avatar
KarmaMag
Havabooz,
I'm not a pro I just happened to have the fender rolling tool available and noone wants to help me.
Zoasis, I know for the fact that you can run 305 in the back. You might have to get custom made wheel with offset around 28 on 10.5" and roll the heck out of your fender. Make sure you check how wide the Hoosier really is. Some race tires are wider than normal.
I'm running 295/30-19 with 10.5" offset 22. The setup clears the fender (after rolling) with no rubbing whatsoever.
Widest wheel I've heard so far is made by Wald @ 11.5" but they have to run narrower tires because the offset won't clear the fender.
Too bad my server doesn't work right now due to excessive bandwidth usage or else I can post some picture for you. Anyone wants to donate the server space???
Old Aug 20, 2003 | 08:25 AM
arvin's Avatar
arvin
Check out my sig. No rolling of the fenders needed. No problems with rubbing whatsoever. Probably its my offset that makes everthing perfect.
Old Aug 20, 2003 | 03:14 PM
patdsaunders's Avatar
patdsaunders
Aoasis,
I just ordered the RPF-1 17x9 +35 (reportadly < 16lbs) with Nitto road race 275/40s for all corners. DTD gave a great price. I do not know anything about these tires, but they are cheap race rubber. What is your offset on your 17x9s?
Old Aug 20, 2003 | 03:31 PM
Todd@ProDyno's Avatar
Todd@ProDyno
From past experience...Hoosiers measured bigger than the industry standard as far as width goes. a 305 Hoosier may be significantly bigger than someone elses 305. Just a heads up
Old Aug 21, 2003 | 10:40 PM
zoasis's Avatar
zoasis
Originally posted by patdsaunders
Aoasis,
Mine are +35 offset front and rear. There is about 1/16" clearance with the suspension on the tires in the front, I hope your tires are not slightly wider than mine. they work very well compared to stock wheels/tires, I'm just looking to go with slightly larger and lower profile Hoosiers.
Old Aug 21, 2003 | 10:43 PM
zoasis's Avatar
zoasis
Thanks for the info, I may need to stick with 285/30's then in the rear.
what setup do you have for me in a 18X9.5F and 18X10.5 Rear setup with and without Hoosiers? I'll probably just slap some used Hoosier on for now.
PM me pricing. I guess SSR Competitions would probably work out OK with 18X9 and 18X10.5.
Old Jan 16, 2004 | 11:40 PM
wayneside's Avatar
wayneside
my buddy is about to put 345/30/19s in the rear of his Z on some wald wheels...huge tires!!!
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
