my I forged evo 20 inch installed pic
Old Oct 6, 2003 | 05:02 PM
Edretti's Avatar
Edretti
What a pair.....of wheels that is
Old Oct 6, 2003 | 05:26 PM
Ralphus's Avatar
Ralphus
How much do the 20's slow down your car over 19's (or stock)? Is it noticeable?
I think 20's look way better, especially yours..
Old Oct 6, 2003 | 06:00 PM
Edretti's Avatar
Edretti
they don't slow down a car at all. Same diameter and same weight but bigger wheels. NICE! 20's fill the wheel wells nice!
Old Oct 6, 2003 | 06:13 PM
350zya's Avatar
350zya
is it possible to run a 35 sidewall all around with 20's? or do you have to run 30 in back and 35 up front? is it bad to have different tire sidewall heights? I want to get 20's but i dont know what trie setup to run??
Old Oct 6, 2003 | 06:14 PM
shortbusrydaz808's Avatar
shortbusrydaz808
Default thanks brother
and you're totally right about it all
have a good one and aloha
Old Oct 6, 2003 | 06:18 PM
shortbusrydaz808
Default the 35 in the front
all the shops didn't want to put 35 in the front because they said it would rub.
not sure if it would but they didn't want to risk it
not sure of the offsets, I'll find out soon as i can though
Old Oct 6, 2003 | 06:22 PM
350zya's Avatar
350zya
does having the differnt tire sizes change the traction control at all have you had any problems with the traction control due to the bigger wheels and differnt tire sizes?
Old Oct 6, 2003 | 06:28 PM
Edretti's Avatar
Edretti
I don't see how you can run the same all the way around. When you go that large your going to have to do 35 frt and 30 rear. You can't even tell the difference. This is needed in order to maintain the same speedo calibration. I have that set up on mine and works great, including vdc.
Old Oct 6, 2003 | 06:31 PM
350zya's Avatar
350zya
so the speedo and vdc works off of the rear tires? thats why you need the 35 sidewall in the rear? I am just trying to get everythign clear befor I drop 4k on 20s and tires.
Old Oct 6, 2003 | 06:49 PM
Ralphus's Avatar
Ralphus
The rear tire is wider, and that 30-35 number is a percentage of the width which is the sidewall size. So you want the rear tire to be a lower percentage of the width of the tire to stay even with the front. Overall, they are almost the exact same height.
245 * 35% = 85.75
285 * 30% = 85.5
So they are as close to the same height sidewall as possible.
Old Oct 6, 2003 | 10:59 PM
shortbusrydaz808
Default ralphus knows
exactly
I have bridgestone potenza so3
front 245/35 ZR20
rear 285/30 ZR20
Old Oct 6, 2003 | 11:01 PM
shortbusrydaz808
Default at the airport
honolulu international airport nissan photo shoot
ma baby
Old Oct 7, 2003 | 01:07 AM
KONVERTER's Avatar
KONVERTER
you need an eibach kit on there and then you will look 100000 times better... or even some tru coil overs and slamm it for shows...
the wheel well isnt a good thing to see at a show...
Old Oct 7, 2003 | 05:13 AM
BDeppe1316's Avatar
BDeppe1316
Love the show car awesome rims....absolutly beautiful. Also, Edretti very nice G35 coupe love the rims also i think i might find you and take them hahahahhaa
Old Oct 7, 2003 | 06:27 AM
Edretti's Avatar
Edretti
Thanks! Thank god your in Stl Louie!
Old Oct 7, 2003 | 05:35 PM
tobydog's Avatar
tobydog
nice *****...errr rims !!
Old Oct 7, 2003 | 05:45 PM
iLLestJrz's Avatar
iLLestJrz
Did you do that yourself or what to your headlights?
Old Oct 7, 2003 | 06:38 PM
  #38
shortbusrydaz808
i had clearcorners.com do all the led conversions on the headlights, front side markers, tail lights, and rear signals
love it
always noticed
Old Oct 18, 2003 | 08:39 AM
  #39
Todd@ProDyno's Avatar
Todd@ProDyno
you're famous!
Page 142 of the November 03 issue of Super Street. Speedlife/Orlando show
Old Oct 18, 2003 | 10:05 AM
  #40
arnelr21's Avatar
arnelr21
Nice
