Rota Grids in 18x9.5 +15 (?)
Old Jan 21, 2009 | 03:09 PM
josesantigo57's Avatar
josesantigo57
Default Rota Grids in 18x9.5 +15 (?)
Im thinkin of getting the Rota Grids in 18x9.5 with +15 offset.
Im going to be mounting these on all four corners for track use.
Will i have fitment problems in the front? I should be fine in the rear.
If not ill go with the +20 setup. Thanks!
Old Jan 21, 2009 | 04:29 PM
Chebosto's Avatar
Chebosto
you'll need to run some negative front camber, but you should be ok. its track setup right? so -2.5 to -3.0 !
Old Jan 21, 2009 | 04:50 PM
josesantigo57
Beautiful, yup i got camber arms waiting to go on the car. Will probably start off at -3 and run R888s in 275.
zhuangzi's Avatar
zhuangzi
I have these wheels, although not mounted yet. Fwiw the face is the same as the +20. Don't know if you'll have clearance issues but from others are runnin +15 doesn't seem too agressive.
azndoc
Wheels Tires
Oct 10, 2015 02:59 PM
tm9293
Wheels Tires
Sep 11, 2015 02:45 PM
