quick tire help
Old Jan 24, 2009 | 08:02 AM
nick123's Avatar
nick123
Default quick tire help
On stock rays from the 06
im planing on keeping my front tires the same 245 40 18 and planing on changing the rear 265 35 19 to 285 30 19
is this gonna throw the vdc into crazy mode
also, will i be taller in the rear..
Old Jan 24, 2009 | 08:11 AM
Z1NONLY's Avatar
Z1NONLY
http://www.miata.net/garage/tirecalcold.html
Old Jan 24, 2009 | 07:11 PM
dhays's Avatar
dhays
I suggest doing just a little reading on your own first so you will be able to gather and learn to use the tools available to answer the question.
However, your proposed tire size will be 2.25% smaller than the stock rear tire. That is within what the VDC will allow (according to the great sticky in this section). However, your rear tire will end up being the same diameter as the front. That is OK, but if I were you I would go with either a 275/35/19 which will be 3.25% larger than the front stock wheel (compared to the stock rear which is 2.25% larger than the stock front) or change the front to 255/40 and the rear to 285/35 which will still retain the 2.25% difference between front and rear and should fit fine.
Those are the two options that I'm considering at least with my '06 GT.
Dave
Old Jan 24, 2009 | 07:20 PM
Originally Posted by Z1NONLY
Excellent tool. Answers 90 percent of all What size tires should I get? posts.
Old Jan 25, 2009 | 08:35 AM
nick123's Avatar
nick123
ahhh...I like the 275 35 19....And since i do not have to change my fronts, I will buy a set of those...THank you very much!!
lapham3
Oct 7, 2022 03:15 PM
350Z_Al
Oct 29, 2020 07:44 PM
