Help!! wheel spacer suggestion
Old Jan 25, 2009 | 11:30 AM
oneqkz's Avatar
oneqkz
Default Help!! wheel spacer suggestion
i was doing alot of search but nothing...anyways i was thinking about 25mm in the front & 20mm in the rear what you guys think ???[IMG][/IMG]
Old Jan 25, 2009 | 11:33 AM
zhuangzi's Avatar
zhuangzi
damn, what size are those wheels, and what's the offset?
Old Jan 25, 2009 | 11:57 AM
Papa bear says 25mm in the front & 20mm in the rear too aggressive.
Momma bear says 25mm in the front & 20mm in the rear too wimpy.
Baby bear says 25mm in the front & 20mm in the rear just right.
Old Jan 25, 2009 | 12:45 PM
oneqkz's Avatar
oneqkz
i totally forgot what's my offset ?? ..but i guess i'll do 25mm in FR & 20mm RR & the wheels are 19s.. thanks davidv for your input
Old Jan 25, 2009 | 01:11 PM
zhuangzi's Avatar
zhuangzi
and with a fatty 25mm spacer, you might want to look into some stronger wheel studs (imho)
Old Jan 25, 2009 | 02:26 PM
Z04's Avatar
Z04
i think that if you got the proper sized wheels with the right offset to begin with, you do not need spacers at all. no reason to join the "fad" if you do not need it.
Old Jan 25, 2009 | 06:45 PM
kelsey_kaye's Avatar
kelsey_kaye
x2... those look like the same offsets as stockers almost.
Old Jan 25, 2009 | 07:55 PM
scotts300's Avatar
scotts300
Take off one front and one rear wheel. Look at the offsets and wheel widths stamped inside the wheel. Share what tire sizes you have on them, and how aggressive you want them to look. Report back.
Old Jan 26, 2009 | 03:17 AM
oneqkz's Avatar
oneqkz
my offset is 25 ..do that sound right ..
Old Jan 26, 2009 | 10:46 AM
kelsey_kaye
front and rears?
Old Jan 26, 2009 | 10:55 AM
d1mon3k's Avatar
d1mon3k
How wide is the freakin' wheel??????!!!!!!!!!
Old Jan 26, 2009 | 11:03 AM
Done Deal DR's Avatar
Done Deal DR
Am I the only one that thinks it looks fine the way it is? Maybe it's just the angle.
Old Jan 26, 2009 | 11:33 AM
scotts300's Avatar
scotts300
Sounds plausible, but what are the rest of the details? i.e. 18x9 +25 front 18x9.5 +25 rear.
You might have this:
or this:
inside the wheel, or both. . .
Old Jan 26, 2009 | 02:10 PM
oneqkz's Avatar
oneqkz
19x9.5 & 19x10 sorry guys
Old Jan 26, 2009 | 02:17 PM
scotts300's Avatar
scotts300
Ok, so it appears you are at 19x95 +25 and 19x10 +25. Now - what size and aspect ratio are your tires front and rear? (xxx/xx/19)
Old Jan 26, 2009 | 02:33 PM
oneqkz's Avatar
oneqkz
sorry scott ..my bad it's..19 x 8 & 19 x 9.5 245/35/19 Front & 275/35/19 in the Rear
Old Jan 27, 2009 | 02:10 AM
oneqkz's Avatar
oneqkz
TTT
Old Jan 27, 2009 | 05:55 AM
zSupreme7's Avatar
zSupreme7
Go 30 front 25 rear.
Old Jan 27, 2009 | 07:54 AM
scotts300's Avatar
scotts300
If his set-up really is 19x8 +25 & 19x9.5 +25 with 245/35/19 fronts & 275/35/19 rears, he has little room for a spacer - especially in the rear. Maybe 10-15mm front and 10mm rear, no way a 30 front and 25 rear though. That would put the front at 19x8 -5 and the rear at 19x9.5 +0, and without superstretchedsilly tires, that just won't work.
Old Jan 27, 2009 | 08:01 AM
Toby-22's Avatar
Toby-22
Looking at the pic, i say do 15mm maybe 20mm all around
