Privat Fahren Question
Old Sep 8, 2003 | 05:57 PM
Apexi350z's Avatar
Apexi350z
Charter Member #50
Default Privat Fahren Question
I am interested in getting the Privat Fahren wheels. I have a couple of questions if anyone can help me.
1. Does anyone have picture of Hyper Gray on any Z?
2. Will the stock pressure sensor (tps) fit without additional metal band?
FYI, I am going to stay with 18x8 +20 front / 18x9 +25 rear. This way, I can still use my stock S03 tires, and upgradable to 245/40/18 front & 275/40/18 rear in the future.
Thank you.
Old Sep 10, 2003 | 03:49 PM
webcarconnection's Avatar
webcarconnection
I have them in Opal my offset are 40 front 25 rear and the tires are 235/40 front and 265/35 rear and fits Perfect!!!
Pics soon!
Old Sep 10, 2003 | 05:42 PM
Apexi350z's Avatar
Apexi350z
Charter Member #50
How come you didn't go +20 front?
Do you know if the stock tire pressure sensor still fits without modification?
Does the wheels require hub ring so it doesn't vibrate around 60mph+?
THanks!
Old Sep 10, 2003 | 08:59 PM
webcarconnection
I go w the 40 because I was worry about the rear wheels offset not the front, either of the front offsets (40 or 20) it wil be good
I don't know about the tire pressure sensor because I have the Base Model...sorry... But I believe it will be fine!
I bougth the Installetion kit that brings the nuts and the adapters for the wheels... you will need it, just $45 more!
Old Sep 11, 2003 | 08:16 AM
CaneZMD's Avatar
CaneZMD
How much are these wheels? and will they work with bigger brakes?
Thanks
Old Sep 11, 2003 | 10:56 AM
Apexi350z's Avatar
Apexi350z
Charter Member #50
webcarconnection, what do you mean installation kit? can't you use factory nuts? also, why do you need the adapter?
CanZMD, you can find them at:
http://www.discounttiredirect.com/direct/home.jsp
Old Sep 11, 2003 | 11:38 AM
PropaGanda's Avatar
PropaGanda
You are interested in the same exact thing I have been asking about. I wanted to see the gray on a black Z. The only difference is, I want 18x9 all the way around with the 25+ offset. I want to put 275/40/18 on the rear. I just need to know what is the biggest size that will fit on the front while still being large enough for the 9 inch wide front rim? Anyone have any comments?
Old Sep 11, 2003 | 12:17 PM
Apexi350z's Avatar
Apexi350z
Charter Member #50
I wouldn't put 9 in the front, I think it's a little too big... but you can probably put 245/40/18 in the front, maybe 255..
Old Sep 11, 2003 | 02:20 PM
webcarconnection
You can't use the factory nuts... the kit bring nuts and a plastic circle to fits the wheels in the rotors ( I can't explain it better... just order the kit) if you call Disc.tire they can explained better.
you can use big brakes on this wheels, but you can call them and make sure about that.
and yes 18x9 is too big for the front!!!
Old Sep 11, 2003 | 06:12 PM
PropaGanda's Avatar
PropaGanda
18x9 is not too big for the front guys. There are people on here running 19x9 on the front and 19x10 out back. I will see if I can get the 255/40/18 for the front. Sounds like that might work. We shall see.
Old Sep 12, 2003 | 12:51 PM
Apexi350z's Avatar
Apexi350z
Charter Member #50
ok, just ordered the rims from my local discount tire store.
18x8 +20mm = $263.00 ea
18x9 +25mm = $270.00 ea
(20) 12x1.25 special lugs = $50.00
17mm key = $5.00
labor+lifetime balance = $96.00
total with tax $1309.48
It will be here next Tuesday, I will post pics when they are mounted. Thanks!
Old Sep 12, 2003 | 01:02 PM
shagz's Avatar
shagz
17mm key = $5.00
Did you go for Opal or Gray ? Is the gray similar to the TE37 gunmetal? I guess Opal is like brushed chrome. Can't wait to see your pictures. I'm torn between the TE37 in gunmetal or the Fahrens. I would really like to get the 90 day same as cash that I can get using the discounttire card. I wonder if they can get Volks, even though they don't have Volks on their website.
Old Sep 12, 2003 | 01:23 PM
webcarconnection
here are my pics of the Opal:
https://my350z.com/forum/showthread....031#post438031
Old Sep 12, 2003 | 01:28 PM
Apexi350z's Avatar
Apexi350z
Charter Member #50
I got the Hyper Gray.. I haven't seen anyone with Hyper Gray yet. The Hyper Gray is lighter than TE37 gunmetal, guess I will find out next week
Don't think they can get Volk, but you can try goto online and talk to someone live.
now I just hope the tire pressure sensor will fit without any modification...
Old Sep 12, 2003 | 02:41 PM
JimH's Avatar
JimH
Default Privat/Fehren
Opal Privat Fahren w/18x8 front (245/40ZR) and 18x9 rear (275/40ZR)
Old Sep 12, 2003 | 04:14 PM
shagz's Avatar
shagz
Default Re: Privat/Fehren
Those wheels really look good, Jim. But I'm thinking if they'll be too much chrome on my already chromesilver car. What do you guys think?
Old Sep 12, 2003 | 04:23 PM
Apexi350z's Avatar
Apexi350z
Charter Member #50
that's what I was thinking, so I got the hyper gray instead... you can wait until I get them to see what it looks like on CS, then you can decide..
Old Sep 16, 2003 | 08:39 AM
PropaGanda's Avatar
PropaGanda
I ordered the Privat Fahren in hyper gray. I got the sizes 18x8 and 18x9 with a 20+ and 25+ offset respectively. I also ordered 245/40/18 and 275/40/18 Falken 451's. I will post pictures of these wheels on my Superblack if anyone is interested. I should be getting the wheels by friday before NOPI.
Old Sep 17, 2003 | 01:33 PM
2k3silver350z's Avatar
2k3silver350z
here's mine from the gallery. the car has been dropped with eibach's. rims are strong too, ran over some nasty potholes and still haven't damaged em.
Old Sep 17, 2003 | 01:45 PM
ColecatZ's Avatar
ColecatZ
Rears look a little tucked in the last pic......but I'm guessing it's the angle. That's a 25 offset?
To any Privat owners, not just the one above: Any pics down the side to see how the offsets flush up?
