What sized spacers would go with this setup
Old Mar 30, 2009 | 08:30 PM
Jon70ProofZ's Avatar
Jon70ProofZ
Default What sized spacers would go with this setup
Just looking for opinions on what size spacers i should get front and back on my 04, running 245 35 19s on the front and 275 35 19s on the back lowered about 1 inch, don't think it needs much but just a little, wheels are 19x8.5 +25 front and 19x9.5 +25 rear thinking maybe 10mm front and back any suggestions would help thanks in advance
anyway heres the pics
Old Mar 30, 2009 | 11:54 PM
_STEVEO_01's Avatar
_STEVEO_01
I think 10mm would be perfect by the looks of it to put you flush, no more than that though or else you are going to either have to roll your fenders or shave the inner liner in your rear quarter panels. Just take a ruler and measure from the wheel/tire out towards the panels that way you can see exactly how far the wheels need to come out. Convert the in. to mm. and there ya go. It is nearly impossible to say EXACTLY just by looking at a few pics...
Old Mar 31, 2009 | 03:09 AM
Z04's Avatar
Z04
actually, those look fine just the way they are
Old Mar 31, 2009 | 04:56 AM
WhiskeyHotel's Avatar
WhiskeyHotel
I agree - those look just fine. You might get get 5-10mm more, but it may not be worth it. (5mm is only about 0.2 inches.)
Old Mar 31, 2009 | 09:40 AM
Jon70ProofZ
i agree you can't tell exactly from pics but thanks for the opinions guys, thinking maybe 5 to 10mm myself just to push them out a little more
Old Mar 31, 2009 | 09:46 AM
reverse's Avatar
reverse
my 5zigens are the same specs. i'm running 20mm all the way around with a 1 inch drop on my G & the back is pretty close to flush.
Old Mar 31, 2009 | 10:03 AM
Jon70ProofZ
^pictures please?
Old Mar 31, 2009 | 12:11 PM
BiggieB15's Avatar
BiggieB15
I would say at least 10mm
Old Mar 31, 2009 | 12:15 PM
Done Deal DR's Avatar
Done Deal DR
I think it looks fine as is, but depending on what you consider "flush" I think you're dead on with 10mm front and rear.
Old Mar 31, 2009 | 01:36 PM
folgrz's Avatar
folgrz
10's up front and 15's in the back
Old Mar 31, 2009 | 05:27 PM
smaha's Avatar
smaha
Not trying to hijack your thread, but I have the same question. My car nearly got totalled in a wreck and the insurance and body shop couldn't find rims to replace mine so I got something similar. Problem is I have no idea what the new rims' offsets are. I put a yardstick up against the fender and measured from rim to yardstick. Both front and back rims are exactly .75" from rim to fender edge. Should I go 20mm spacers front and back (eventually I plan to put coilovers on but not with the intent of slamming it)?
Old Mar 31, 2009 | 06:07 PM
_STEVEO_01's Avatar
_STEVEO_01
I am assuming that by .75", you are referring to 3/4 of an inch (19mm)... If that is the case, 20mm would sit you perfectly flush. Now that I think about it, what size tires are you running? If it isn't stretched, 20mm is going to put you very close to rubbing with the wrong tire... It is hard to tell without specs and a visual.
Old Mar 31, 2009 | 06:30 PM
sry110's Avatar
sry110
I think 10 mm front and rear would look good.
Old Apr 1, 2009 | 05:21 PM
smaha's Avatar
smaha
...yup, 3/4" is what i was referring to. 235/35/19's on 8.5" rim up front and 275/30/19's on a 9.5" rim in the back. so would i be safer going with 15mm front and back?
sales@czp
Sep 23, 2019 03:30 PM
