What size wheels and offsets are better for this set-up?
Old Apr 12, 2009 | 06:02 PM
Sora1421's Avatar
Sora1421
Default What size wheels and offsets are better for this set-up?
I have finally deciding on going 245/40/18 all around on a square-set-up with most likely a hotchkis drop to even out the wheel gap increase (mainly in the rear) since you can't SLAM cars around here.
The wheels I am looking at come offer these options.
18x8.5 42 offset
18x8.5 35 offset
18x8.5 24 offset
18x9.5 42 offset
18x9.5 25 offset
I want to know what you guys think would look the best. I want the tires to come out more even with the fenders than being tucked away inside, also with as little wheel gap as possible since obviously until I get a drop 245/40/18 in the rear will create some gap.
would 18x9.5 with a 25 offset give me what I want? That's what I was thinking.
I appreciate any thoughts comments or even flames hah. If spacers will help me reach my goal please suggest some as well, I am trying to learn here but I learn best by example.
Old Apr 12, 2009 | 06:56 PM
terrasmak's Avatar
9.5 +25 and i would suggest 255/40 or better yet , go with a staggered setup. Why the nonstaggered square setup?
Old Apr 12, 2009 | 07:08 PM
Sora1421's Avatar
Sora1421
Because the this is the best set-up I have seen for the tires I am looking at. I can't spend too much on wheels and tires so I'm choosing cheap but acceptable Nexen N3000 tires so I can spend more on wheels.
With the 9.5 +25 I would probably need a spacer to make he tires come out more?
Old Apr 12, 2009 | 07:30 PM
A 245 mm tire works well with a 8.5 inch wheel. That's a functional comment. Looks are up to you.
Old Apr 12, 2009 | 07:33 PM
Sora1421's Avatar
Sora1421
Will 9.5 with the same offset as a 8.5 wheel give a bigger lip. or does that have nothing to do with the lip. Also on 245 on 9.5 will stretch the tires correct? Is 245/40/18 safe on 9.5 width? I figured they would be correct? Sorry all the questions...i'm just trying to figure everything out.
Old Apr 12, 2009 | 07:34 PM
Motormouth's Avatar
Motormouth
no offense br0. but none of those setups will look particularly good.
but the lowest offset will look the best, and a 8.5 (as david said) will make the 245 the least stretched and fill up the fender well more.
I don't know why you want a 245 set up so bad, but whatev.
I hope the rim design doesn't suck..
Old Apr 12, 2009 | 07:45 PM
Sora1421's Avatar
Sora1421
Once again It's either 245/40/18 all around, or i move to the 35 profiles on 18's since Nexen doesn't offer anything larger than 245 on 40 profile 18's. Which would make a huge wheel gap
Old Apr 12, 2009 | 07:47 PM
Offset is the distance between the center of the wheel and mounting surface. Offset and lip have no relation.
I would not run a 245 mm tire on a 9.5 inch wheel.
Old Apr 12, 2009 | 07:52 PM
Motormouth's Avatar
Motormouth
davidv, depending on the wheel style, lowering the offset can increase the size of the lip.
and Sora:
I don't know why you want those terrible tires, and then limit yourself by them.
if you are going to run a square set up, don't limit yourself to those sizes. you should do the 9.5 +20 and a 265 all around.
Old Apr 12, 2009 | 07:56 PM
Sora1421's Avatar
Sora1421
and Sora:
I have read multiple reviews an d the N3000 are comparable with the FK452's, sure the falken are a little better but the N3000 have still pretty good traction and treadlife while remaining a few hundred cheaper for a set of 4. That leaves me with a few hundred more for better rims. This is my daily driver which I drive around town and every now and then i hit some back-roads, these tires are IMO perfect for me. I have seen multiple people run 245 all around and it still handles well. Like I said, i drive my Z through town to work and school and that's usually about it.
Old Apr 12, 2009 | 07:58 PM
Motormouth's Avatar
Motormouth
as I said, if you are sticking to 245s, it will never look 'great', but going with a low offset 8.5 is your best bet to have a decent looking set up.
Old Apr 12, 2009 | 08:06 PM
Sora1421's Avatar
Sora1421
I live in an area where primered civics, integras, and neons are common, and I understand my budget so "decent" is all I can expect really but I feel it will be plenty good enough. Anything is better than these god-awful stock 17's. Come next summer maybe I will have enough money and be ready to move on to some really nice wheels/tires but for now "decent" is exactly that, and that's good enough for me considering I have like one of the only 3 Z's in the area.
Old Apr 12, 2009 | 08:38 PM
Motormouth's Avatar
Motormouth
when I had the stock 17s, I upgraded to the stock 18 inch OEMs... I really like them and a 245 looks great on them (until you lower the car that is, then the offset sucks... +30 btw).
two other options are the stock track wheels which are 8 and 8.5 rear. or the GT rims which are 18x9/19x10 stagger and look excellent.
where in PA are you by the way? and what rims were you actually looking at, and what is your budget?
Old Apr 12, 2009 | 09:12 PM
Sora1421's Avatar
Sora1421
I am not looking to spend more than 1300-1400 total on wheels and tires for right now. I can get a set of nexens for about 380 shipped which leaves me around 1000-1100 for a set. I would buy used but I'm charging this all to a 1500 limit credit card that has 0% APR since I don't have much to spend after buying this Z but I need new tires on it soon anyway so I figured to get them all at once. I was looking at some different Enkei rims currently. If i wasn't charging to a card I would buy good used ones. I don't need anything super light since I'm not tracking it or racing it. I just want something lighter than stock that are durable quality.
I am about 40 miles south of Pittsburgh...there's not much here, including things to do or money.
Old Apr 12, 2009 | 09:16 PM
Motormouth's Avatar
Motormouth
you can use your card through paypal if that is necessary.
and I was about to point you to the guy who is selling the really nice Ray's GT set up I mentioned with brand new tires for 1800. but that is slightly out of your range.
I suggest looking at tirerack if they carry nexens, because don't forget M/B is about 100 bucks + possibly shipping for your parts. if you do rim/tire through tirerack you save on both of those.
at 1k you can get a few different decent rims though.
Old Apr 12, 2009 | 09:19 PM
Sora1421's Avatar
Sora1421
I had no idea you could charge credit cards through paypal...i may start browsing for some nice used ones. What would you suggest if i had to buy brand new around 1k?
Old Apr 13, 2009 | 02:07 PM
boosted99gst's Avatar
boosted99gst
g35 19's with spacers and a drop can be done for about 1400....just a thought.....
Old Apr 13, 2009 | 04:31 PM
terrasmak's Avatar
245/45/18 is offered in that Tire, get those in the back with the 245/40 front and put them on either the 8.5 or 9.5's and call it a day. I would get the 9.5's all around, i don't mind a little stretch. You would even stagger 8.5 front and 9.5 rear if you want with my posted tire selection.
Old Apr 13, 2009 | 08:28 PM
Motormouth's Avatar
Motormouth
a little stretch on a 9.5 on stock height?
Old Apr 14, 2009 | 12:48 PM
Sora1421's Avatar
Sora1421
I do plan on a hotchkis drop I did say
