Spedo Adjustment
Old Sep 16, 2003 | 07:09 PM
jasons04Z's Avatar
jasons04Z
Default Spedo Adjustment
I just bought a base 350z and id like to add 19" wheels But, how is the spedo going to be adjusted When i had a crustang all i had to do was change a gear in the spedo cable. What do they do with the Z?
Old Sep 16, 2003 | 07:11 PM
Stone Z's Avatar
Stone Z
If you run 275/35 or 285/35 in the rear you shouldn't have to calibrate at all. You'll be off, but only like one mph in either direction.
Old Sep 16, 2003 | 07:33 PM
Jedi's Avatar
Jedi
Default NAvi Accurate now
Maybe you'll get lucky, like I did with my Acura TL I used to own, and the Navi will be more accurate! LOL Assuming you have one.
Old Sep 17, 2003 | 04:05 AM
jasons04Z's Avatar
jasons04Z
Sorry, no nav its a base model with 17' wheels
Old Sep 18, 2003 | 06:15 AM
D_Nyholm's Avatar
D_Nyholm
Well, I noticed that my speedo reads about 4% LOWER than what I am really going. I am hoping to get some tires that are a little smaller (245-40-18) and hope that will correct it a little bit....that way I will be about 1% high or more or less right on....
I also heard that the sensor might be in the front wheels, so my thought is out if that is the case.
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
