Confirmed: 9.5 will NOT fit on front...
Old Sep 20, 2003 | 01:16 AM
ADMAN's Avatar
ADMAN
Default Confirmed: 9.5 will NOT fit on front...
Week 5 and still waiting for my front wheels on a slow boat from
China. So, I thought I'd slap a set of 9.5 on the front with 275/40
all the way around. Well, the friggin' rim rubs the a-arm. So, I
have to wait...
ADMAN
Old Sep 20, 2003 | 01:49 AM
MY350Z.COM's Avatar
tire rubbing or wheel rubbing?
i think there are a few guys running the 9.5" front with 245's OK
Old Sep 20, 2003 | 06:13 AM
tig488's Avatar
tig488
i got 9.5 on front +35 offset and 275/30s
Old Sep 20, 2003 | 06:47 AM
mikeyngo's Avatar
mikeyngo
John350z has 9.5 SFW 19 with a 22+ offset. His fenders was rolled. I don't think you can use 9.5 in the front without rolling ur fenders.
Old Sep 20, 2003 | 08:37 AM
03_ppw350z's Avatar
03_ppw350z
i have 9.5 front with 34 offset 245-35 tire no problems and my car is lowered 2 inches
Old Sep 23, 2003 | 12:54 PM
VQ35DES's Avatar
VQ35DES
man, thats hella wide
Old Sep 23, 2003 | 01:23 PM
Mr B's Avatar
Mr B
I've got 10" in front but will go down to 9.5 to accomodate for future mods that were not foreseen when the wheels were made.
Old Sep 23, 2003 | 03:55 PM
Lateapex's Avatar
Lateapex
You have an offset problem, not a wheel width problem.
Old Sep 24, 2003 | 02:46 AM
MATIX's Avatar
MATIX
Thers no part to roll on hte front fender
Old Sep 24, 2003 | 12:06 PM
Mr B's Avatar
Mr B
Eh? I rolled my front Colin...
Old Sep 24, 2003 | 01:40 PM
MATIX's Avatar
MATIX
What did you roll? The front fender doesnt have the horizontal piece of sheet metal o nthe inside of hte fender that the rear does...
Old Sep 24, 2003 | 01:59 PM
DrCold's Avatar
DrCold
I'm runnin 19x9.5 in the fronts with 255/35's. I think im going to go up to 275 (265 would be nice if i could find them) in the front and 295 rear. Thats what these wheels are begging for.
Old Sep 24, 2003 | 06:53 PM
HREWheelMaker's Avatar
HREWheelMaker
With the correct offset, 18x9.5 or 19x9.5 will easily fit on the front of the 350z with no modifications.
Our 2002 SEMA 350Z show car had 19x9.5 front (275/30-19) and 19x10.5 rear (295/30-19) and was lowered with Eibach springs. I drove the car for over a month, and it never rubbed.
How far off are your wheels? Perhaps you could use a small spacer...
Old Sep 25, 2003 | 12:50 PM
Mr B's Avatar
Mr B
Colin, you can check out my fenders next time.
Old Sep 25, 2003 | 01:03 PM
DrCold's Avatar
DrCold
If you dont mind me asking, what brand of tires did you use? I've been trying to find some in those sizes, but it seems like one company will make on size, while another will me the other size i need.
Old Sep 25, 2003 | 01:14 PM
HREWheelMaker
We used the new Pirelli P-Zero Rosso. These are an asimmetrical tire (not directional), so you would be able to rotate them left-to-right on the same axle, if desired.
My experience with them showed them to be very quiet and predictable, with no evidence of 'tramlining' on the freeway. Even after 5,000 miles, there was very little sign of wear- I would recommend them highly for the 350z
Old Sep 25, 2003 | 01:19 PM
DrCold's Avatar
DrCold
Really? Cool. Thanks for the info. A few people i know seem to shy away from Pirelli tire because they wear out to quickly. After i wear out these Toyo's i'll have to check into those. Thanks again.
Old Sep 25, 2003 | 05:09 PM
redlinez's Avatar
redlinez
Continental makes that combo also 275/30 and 295/30 and cheaper too!
Continental tires
Old Sep 26, 2003 | 10:14 AM
z327's Avatar
z327
What offsets?
Old Sep 26, 2003 | 09:02 PM
zoasis's Avatar
zoasis
A lowered Z will have negative camber in the front so rolling the fenders on the fronts may not be necessary with the 9.5 width. On my Enkei RPO-2J's 17X9 with 35mm offset and 275/40's mounted on the front, they have about 1/16 of an inch room on the inner A-Arm. The outer portion of the tire has PLENTY of room, I'm sure a 9.5" rim will easily fit with the proper offset.
Anyone know of a lightweight 18X9.5 rim for the front?
